How do you set MaxFanInPorts for MSRP on an AVB enabled switch?
  • Question
  • Updated 2 years ago
  • Answered
I'm unable to find the option to set MaxFanInPorts on any AVB enabled switch I have and I didn't see the option in the manual either.
Per the AvNU documentation on MSRP:
MSRP provides a parameter that may
alleviate this potential problem in some cases if it does occur. By setting
msrpMaxFanInPorts to a non-zero value less than the total number of ports,
latency could be reduced. The price for the reduced latency is the reduction in
the number of ports that can simultaneously have active listeners attached to
them.
TGDAVIDF01.1 # sh msrp
MSRP Status                           : Enabled
MSRP Max Latency Frame Size           : 1522
MSRP Max Fan-in Ports                 : No limit
MSRP First Value Change Recovery Time : 30000 (ms)
MSRP Ignore Latency Changes           : Off
MSRP Talker VLAN Pruning              : Off
MSRP Boundary Change Rate Limit       : Off, Limit 16, Period 30 seconds
MSRP Reservation Rate Limit           : Off, Limit 125, Period 1 seconds
MSRP Enabled Ports                    :  47     48    *52ab
MSRP Sharing Bandwidth                : Master Port only
Total MSRP streams                    : 0
Total MSRP reservations               : 0
Flags:  (*) Active,              (!) Administratively disabled,
        (a) SR Class A allowed,  (b) SR Class B allowed,
        (g) Load sharing port
I know how to set this in a Netgear AVB switch and even in the new Cisco AVB enabled models, how do I set this option in the Extreme switches?
Photo of Ron Prague
Ron Prague
  • 742 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Chad Smith
Chad Smith, Alum
  • 5,640 Points 5k badge 2x thumb
Ron,
I see that you have also opened a GTAC case for this.  I'm not sure if this is currently possible.  We are investigating.
Photo of Ron Prague
Ron Prague
Yeah, sorry for going through both channels, but this has become a hot issue internally.
Photo of Balaji
Balaji, Employee
  • 776 Points 500 badge 2x thumb
Ron,
Currently there is no  provision in EXOS to configure the MaxFanInPorts.
Photo of Ron Prague
Ron Prague
Thank you, I've been told via our ticket that there is an engineering request (case# 01221072) to add this ability.
