How I can check port-up-down trap settings in Summit Ver2 Stack ?
  • Question
  • Updated 2 years ago
  • Answered
How I can check  port-up-down trap settings in Summit Ver 2Stack with ExtremeXOS (Stack) version ?
Photo of Weda
  • 994 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Weda,
Have you tried the following command,
"show port <port number> info detail"
You can look for the setting in the output as below:
Link up/down SNMP trap filter setting:  Enabled
Also, you can verify the configuration by filtering them using the following usage:
"show configuration detail | include port-up-down"
Hope this helps!
Let us know if you are looking for any other command.
Photo of Henrique
Henrique, Employee
  • 10,282 Points 10k badge 2x thumb
Just an addition:
You can enable/disable port-up-down SNMP trap using the following command:
[enable | disable] snmp traps port-up-down ports [all | <portlist>]
