How many maximum user create in VC?
Saravanamurthy_
Contributor
I am using AP 7532, firmware is 5.9.2. This is a Virtual Controller. I configured captive Portal with out NAC. In this VC what is an Maximum radius user?. If we connect one user id, Only one person should use the same time. How to configure in GUI for AP 7532?
2 REPLIES 2
Ondrej_Lepa
Hi Saravanamuthy,
this is a complex topic with multiple questions so let me sort it out a little:
Maximum RADIUS users
    Testing on AP7532 I reached below error for RADIUS user pool % Error: Cannot add user SPbFx_gu_291. Pool has maximum users (256).
    Testing on VX9000 I reached below error for RADIUS user pool % Error: Cannot add user xKBV9uSr. Pool has maximum users (20000).
Only one person should use credentials
    Command you are looking for is "simultaneous-users x" in Captive Portal policy The number of MAC addresses that are allowed to use that username at the same time.
How to configure in GUI on AP7532
  • if your AP has Enterprise UI, then do it here (Configuration - Services - Captive Portal)
In case the AP does not have Enterprise UI, read article how to change SwiftUI to Enterprise
Here you can also find reason for 404 server error when accessing WebGUI in case you use LEAN image.
Regards,
Ondrej
Andrew_Blomley
The VX will support 256 users, it is also possible to limit the number of devices that can log into the the captive portal with a single user name
