How many maximum VRF on X670-t ?
  • Question
  • Updated 3 years ago
  • Answered
Hi all,
I have extreme network x670-t, and I will use VRF but i don't maximum VRF can be provide. So Do you have experience maximum VRF can be created on my extreme network devices ?
Thanks
Regards
Fandi kurnia
Photo of fandi kurnia
fandi kurnia
  • 100 Points 100 badge 2x thumb
  • thanks
Posted 3 years ago
Photo of Derek Bird
Derek Bird, Employee
  • 576 Points 500 badge 2x thumb
Greetings, Fandi!
The maximum number of VRFs (or any feature) can be found in the Release Notes for the version of EXOS you're running.  The section you'll look for is is the "Limits" chapter.
For instance, the release notes for 16.1.3 indicate the maximum number of VRFs is 960.
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Just to complete, you can download the Release Notes using the link below (Under ExtremeXOS section):
http://www.extremenetworks.com/support/release-notes
