How much square footage do you usually estimate a single Extreme AP7532 covers?
  • Question
  • Updated 6 months ago
  • Answered
I have a new warehouse in which we rent 10,000 sq ft and would like to provide Wifi for our scanner guns to work from.
This site is fairly far and am trying to save on the travel expenses.
I would like to try to estimate how many APs is needed to give them sufficient Wifi coverage.
There will be normal warehouse racking stacked with product and the ceiling is looking to be around 60ft high.
Is there good method to estimating how many APs they are going to need if we're going to use an Extreme AP7532?
Photo of Jacob Airov
Jacob Airov
  • 308 Points 250 badge 2x thumb
Posted 7 months ago
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,070 Points 1k badge 2x thumb
Hi Jacob,
This is an impossible question to answer without lots and lots of additional questions and information.
Wi-Fi rule #1 stipulates all Wi-Fi networks need to be properly designed using appropriate software such as Ekahau or Air Magnet.
Warehouses are a particularly challenging RF environment and require specific design considerations for Wi-Fi networks to operate correctly.
I recommend asking your client for plans for the warehouse and using the RF planning and design skills of a professional Wi-Fi architect.
Regards,
Darrel.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
You'd use the Extreme wirlessplanner
https://wirelessplanner.extremenetworks.com/
Documentation....
http://documentation.extremenetworks.com/rf_planner/RF_Planner/Quick_Reference/c_accessing-tool.shtm...
It doesn't include WiNG APs but you'd use another type to estimate the coverage.
Cheers,
Ron
Photo of Andrew Webster
Andrew Webster
  • 1,756 Points 1k badge 2x thumb
60ft high is quite high, so you need to take into consideration that your guns will always be a minimum of 57 feet away from the nearest AP.
Have a look at https://wirelessplanner.extremenetworks.com  you should be able to generate your estimate from there, while it doesn't specifically have the AP7532 in there (hint-hint), the equivalent Extreme AP would be sufficient to get a good idea of how its going to work.
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,082 Points 4k badge 2x thumb
The best way to estimate how many APs is needed to perform a wireless site survey.
A wireless site survey sometimes called an RF site survey or wireless survey is the process of planning and designing a wireless network, to provide a wireless solution that will deliver the required wireless coverage, data rates, network capacity, roaming capability and Quality of Service (QoS).
As part of the wireless site survey, the effective range boundary is set, which defines the area over which signal levels needed support the intended application. This involves determining the minimum signal to noise ratio (SNR) needed to support performance requirements.
Photo of JESUS REYES DIAZ
JESUS REYES DIAZ
  • 222 Points 100 badge 2x thumb
My suggestion take one AP , set at medium power range AND make measurents with the Guns AND. Fusión software .
Photo of Shay Weir
Shay Weir
  • 1,648 Points 1k badge 2x thumb
Setting an AP at a default power of 10, the coverage starts lifting off the floor at around 35 feet.  Your design will need to include setting AP height to 60,  adjust your power up to about 15-17 if not 20 to force the signal down low enough.  Also, DO NOT use the smart-rf policy to manage this.  Static all power and channels.
Rack height, number of and space between them also will play onto your design.  Airmagnet and others will allow you to draw in the resistance for the racks.  Set them to high density for max attenuation.
You will will be deploying a very high density of APs to provide good coverage.
Airmagnet is my choice for doing these.  As stated above, you need a very good detailed floor plan to start with.  That is the key.  Rely on your support staff on site to provide pictures of the environment so you get a clear understanding of what you are about to deploy.
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
Number 7 with the same information...
Do a WiFi design, do you have knowledge of this? You can do a simulation. If not, get knowledge, do a training what ever.
You can read this, step 1 and 2 are important for you, for now. You can also check this.
During the older days you do a lot of site surveys. AP on a Stick, walking on site and check all locations. Today I don't do this in 90% of my customers.
Just doing Simulations, but you need knowledge for this.
Biggest problem on WiFi, it mostly works, also with very poor designs. But a good design gives you a better WiFi and saves money. Sometimes it saves a lot of money!
All answers before have right informations. But most important is, that you know what you do.
Do a "site survey" with the end device, great information, but bad to document.
Do a "site survey" with a tool like Ekahau or AirMagnet, great to document, but don't forget to compare it to you end device.
Do a "simulation" with a tool like Ekahau or AirMagnet, very flexible, but you need knowledge.
Use a vendor tool from the producer of the APs? I'm not a fan of this, mostly marketing/sell stuff, not technical stuff.
But based on your basically request, I'll recommend to search for a local WiFi dealer and request a simulation or site survey from this company. Maybe the best solution for you. If you get more request like this, do a ECSE training. Perfect information for starters, a lot of CWNA stuff and not just Ekahau stuff.
Photo of Norwin Uy
Norwin Uy
  • 60 Points
We have a 30k sqft warehouse with a similarly high ceiling. Our guns do basic terminal emulation and have older 802.11g radios. I implemented 6 WiNG 7532s spaced strategically, with only 4 mapped to the SSID that's serving the RF guns. Coverage has been fantastic. As others have said, a site survey would be ideal, but these APs can get you going especially if your primary network need is simple (like terminal emulation).
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Agree with " Robert Zarzycki ", site survey is one of useful ways to estimate AP.
Then, the next question will be which tool should I use. Maybe there is no right answer.
I like to use Ekahau. You could read the follow blog from Ekahau.
https://www.ekahau.com/blog/2015/09/16/ekahau-site-survey-heatmap-visualizations-part-10-number-of-a...
Hope it will help!
