How Restore deleted Users in NetSight interface in Java / OneView users?
  • Question
  • Updated 3 years ago
  • Answered
What is the procedure on the server to assign a user created to access the web interface or java?
Photo of Jairo Rojas Herrera
Jairo Rojas Herrera
  • 1,452 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,186 Points 50k badge 2x thumb
Jairo Rojas Herrera
Excellent, but I do not have access to only the server console. I think as a group and assign the user from the server? by CLI.
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Jairo, are you using Linux Server? If understood correctly you have access to the server but not to the Console/Java.
If you are getting wrong username/pass for an specific user you can try to reset the username pass.
Jairo Rojas Herrera
If I'm on a Virtual Server Appliance.
I can enter along with any user via SSH to the server but not Java.
The TAC tells me that according to the logs were removed users, now how do I asiganarlos for aceceso for Java?
Jairo Rojas Herrera
Sorr,
Yes I am on a Virtual Server Appliance.
The TAC tells me that according to the logs were removed users, now how do I assign them for access by Java?
Photo of Henrique
Henrique, Employee
Did you try to add a new user to the linux OS with "adduser" option and launch the Java Client?
Jairo Rojas Herrera
Hi Henrique,
No Access with this instructions
Photo of Henrique
Henrique, Employee
Hi Jairo, please follow the procedure below (type all characters):
  1. SSH to Netsight Server and login using root credentials
  2. cd /usr/local/Extreme_Networks/NetSight/scripts
  3. ./mysql.sh
  4. use netsight;
  5. select * from nsproperties;
After step 5, please share the outputs.
