How to access c5210 wireless controller version 09.21.09.0004 through management or serial interface ?
  • Problem
  • Updated 11 months ago
  • Not a Problem
i am trying to deploy a newly purchased c5210 wireless controller version 09.21.09.0004 . I have followed the steps on "9034715-01_C5210_QR.pdf". Firstly I tried to access to controller from eth0 (Mgmt port)
> assign my laptop 192.168.10.66 /24
>> but unable to ping 192.168.10.1 or access https://192.168.10.1:5825
> then I tried to access through serial port using credentials "admin" and "abc123"
>> but login denied. Here is the output:
Backup-EWC-172.16.245.3 login: admin
Password:
Login incorrect
Photo of Yakup Erdol
Yakup Erdol
  • 590 Points 500 badge 2x thumb
Posted 11 months ago
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,110 Points 2k badge 2x thumb
Hi Yakup,
it seems to be that some config retains in the EWC?!
Anyway during the boot you can have the option to log in the rescue mode where you can delete the password .
Regards
Umut
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
(Edited)
Yakup Erdol
Hi Ronald,
I am new to Extreme wireless. But I have to complain that documentation is awful.
Thanks.
Yakup Erdol
Hi all,
Reseting password solved my problem. But I can not understand why a new product comes with configuration on it.
Thanks for quick help.
New products don't come with a configuration.... beside the default one.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Ron is correct, it should not have a configuration on it. The getting started guide should help you install the product. https://extremenetworks.box.com/s/gmf4d4rafoxmd1h846x97bg6zgiul5jm
That shows pretty much that this controller was in use before as it's not the default host name.
I'd ask whoever sold it to you what they have done with the controller prior to selling it to you.
-Ron
