How to activate ports 49-64 on X670-G2?
  • Question
  • Updated 1 year ago
  • Answered
Switch: X670-G2
FW:  21.1.14
Hi guys,
I would like to add some ports (49 to 56) to the switch using two OSPF 4x10G Modules. When inserted the two modules I see the following:
Port Summary Monitor                      Thu Dec  1 09:07:50 2016Port  Display              VLAN Name          Port  Link  Speed  Duplex
#     String               (or # VLANs)       State State Actual Actual
48                         OK20                E     A     10G   FULL
49                         OK20                E     R
50                         OK20                E     NP
51                         OK20                E     NP
52                         OK20                E     NP
53                         OK20                E     R
54                         OK20                E     NP
55                         OK20                E     NP
56                         OK20                E     NP
How do I manage to get all ports ready?
Greetings Jory
Photo of Jory Kienstra
Jory Kienstra
  • 82 Points 75 badge 2x thumb
Posted 1 year ago
Photo of OscarK
OscarK, ESE
  • 7,482 Points 5k badge 2x thumb
When the ports are in 40 Gig mode you will only have port 49,53,57 and 61 available for use. If you partition the ports to 4x10 Gig you will have the NP (Not Present) ports also available.
conf port 49 partition 4x10G
conf port 53 partition 4x10G
conf port 57 partition 4x10G
conf port 61 partition 4x10G
Jory Kienstra
Thanks for the quick responds Oscar
Photo of Ariyakudi Srinivas, Muthuraman
Ariyakudi Srinivas, Muthuraman, Employee
  • 964 Points 500 badge 2x thumb
The command to partition the ports is as below,
configure ports [port_list | all] partition [4x10G | 1x40G | 1x100G | 10x10G ]
After you make a configuration change, you must do one of the following to apply the change:
For X670-G2 and X770 switches you can reboot the switch.
