how to active access point ws-ap3805i connect to wireless controller c35
sabou_Doumbia
New Contributor II
5 REPLIES 5
Claudio_D_Ascen
New Contributor III
You are welcome Sabou
Ciao Claudio
sabou_Doumbia
New Contributor II
Hi Claudio
ok I try this and i tell you if it is ok
thx for your answer
sabou_Doumbia
New Contributor II
Hi Gareth
I have a wirelless identifi c35 and 3 AP 3805i
it is a new equipement for me it is my first-time for use this equipement
i learn more document and I managed to open and add Ap ip and topology but AP status is inactive
Gareth_Mitchell
Hi Sabou
We would need a bit more information than what you have provided, some of these articles might help in the meantime:
https://gtacknowledge.extremenetworks.com/articles/Solution/New-Access-Points-are-not-Connecting-to-...
https://gtacknowledge.extremenetworks.com/articles/Q_A/Minimum-firmware-version-for-WS-AP3805/
You can also review the discovery and registration section of the online manuals:
https://documentation.extremenetworks.com/wireless/v10_41/UG/Wireless/User_Guide/c_discovery_and_reg...
If the above doesn't help, I recommend you get in touch with the GTAC directly.
-Gareth
