how to active access point ws-ap3805i connect to wireless controller c35
  • Question
  • Updated 3 months ago
  • Answered
Photo of sabou Doumbia
sabou Doumbia
  • 158 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Anton Sax
Anton Sax
  • 956 Points 500 badge 2x thumb
is that ap connected over WAN/VPN? is a ping from ap to ewc possible?
if yes check AP -> Static configuration -> Tunnel MTU and lower that value eg 1300 instead of 1500
sabou Doumbia
hi ,
No ping  AP it not possible
and I change MTU but no result.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 44,170 Points 20k badge 2x thumb
Hi, the screenshot shows an AP3825i and not an AP3805i.
Because you don't provide any details about the steps you've performed or i.e. a network diagram I don't see any chance to help you..... i.e. the AP in the screenshot could be manualy added or it was discovered which is a big difference.
The best advice I'd give you is to pay a Extreme Partner to install/configure it for you and also give a brief workshop so you'd perform configuration in the future by yourself.
BR,
Ron
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,030 Points 2k badge 2x thumb
check out your license..I hope it's not in a DEMO mode?
Need enter a eval license or get a valid license.
Regards
Umut Aydin
Photo of Umut Aydin
if AP3805 in question ..seee please this one.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Minimum-firmware-version-for-WS-AP3805
Rgds
Umut Aydin
