how to add port groups to Eaps Domain in Netsight ?
  • Question
  • Updated 2 years ago
  • Answered
In Ridgeline you would create port groups and associate those port groups to a defined Eaps Domain and run a script to add a new vlan to those ports. How would you perform this in Netsight 6.3 ?
Photo of Tiburcio Jr Coronado
Posted 2 years ago
Photo of Tony Thornton
Tony Thornton, Extreme Alumnus
  • 1,412 Points 1k badge 2x thumb
Hi Tiburicio,
This related conversation may be helfpul:
https://community.extremenetworks.com/extreme/topics/easiest-way-to-add-a-eaps-protected-vlan-with-n...
You can add ring ports to EAPS rings along with other actions.
Tony
I have tried this and does not work for me, it creates the vlan and tags it, it fails when ithe script tries to add to the ports  have selected in the  Eaps script
In Ridgeline you would create port groups, from there you would sync which eaps script you wan to add to those port groups.
Are there any messages from the script wizard corresponding to when it fails indicating why it failed?  Any messages in the switch log created when the script is run?
Sorry, my mistake, are ports 1:6 and 2:6 need to be members of vlan piw_inet_test_burke2_1014?  They need to be.  burke_commerce is the EAPS domain.
Ooops hit 'send' before I proofread my reply.  Those ports need to be members of vlan 'piw_Inet_test_burke2_1014'.
I have opened a GTAC case. Netsight is not pulling in port information from Port Element groups.
Ok, thanks for the update.  I think you'll get this solved in no time with GTAC's help!
Have a good day
