How to alert for uplink RX or TX errors on uplink port (XOS and netsight)
  • Question
  • Updated 10 months ago
  • Answered
Hello,
We use netsight 7.1 console to do basic traps and syslog.  Is it possible, that netsight could send me an email alert if a problem was seen on an *uplink* port to a stack.  I don't want to have to manually run a report, I'd like to have an email sent out like we have for our traps.
Setup:  460 g1s running 16 code (XOS) ports 1:53-54 are shared lacp
Sometimes the fiber at our locations degrades overtime and affects the uplink (Massive TX or RX errors are seen with the show port 1:53-54 rx or tx is ran).
Is there a way for netsight or the switch itself to monitor these ports, so we can be alerted when things start building up?  We have port elements setup in netsight, but I can't seem to see any option that would fit in that setup.
Any other options you can think of?
Thank you,
Sarah
Photo of Sarah Seidl
Sarah Seidl
  • 1,356 Points 1k badge 2x thumb
Posted 10 months ago
Photo of Volker Kull
Volker Kull
  • 1,862 Points 1k badge 2x thumb
Hi !
If you see these errors on interface statistics for
Statistic Name: Interface % Error Packets. Source: ifInDiscards + ifOutDiscards + ifInErrors + ifOutErrors + ifInUnknownProtos
you can use a threshold alarm in Netsight alarm manager for %error packets. For this you need to enable interface monitoring (Monitor - Save statistics for 1 hour and then drop. Use this mode for threshold alarms.) on the ports you want to monitor.
I am not sure if you will see all the errors there but it can be an indicator.
br
Volker
Sarah Seidl
thanks for the idea, will check it out
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
Sarah Seidl
That looks promising, thank you!
