How to back up configuration a C5210 identifi wireless ??
  • Question
  • Updated 10 months ago
  • Answered
Hello can you help me to back up configuration of C5210!!!
Photo of Angel Pavon
Angel Pavon
  • 544 Points 500 badge 2x thumb
Posted 10 months ago
Photo of Hawkins, Bruce
Hawkins, Bruce, Employee
  • 888 Points 500 badge 2x thumb
Controller>Administration>Software Maintenance>Backup.
There are options there to allow you to do a one time manual backup, or to schedule backups on a rotating basis, daily, weekly or monthly ... and to be able to set it up to those backups are copied off the controller via FTP to a 'safe' location.
If you have a V2110 running on Vmware, taking snapshots of your configuration is also a good idea.
Photo of Darin Seiler
Darin Seiler
  • 402 Points 250 badge 2x thumb
Go to Controller, then Software Maintenance, then Backup. That is where you backup a C5210.
Photo of Craig Guilmette
Craig Guilmette, Employee
  • 2,410 Points 2k badge 2x thumb
Angel Pavon
Thanks a lot!! Craig. It was ver helpful :)
Regards
