How to block client use Wing 5.8
  • Question
  • Updated 1 month ago
  • Answered
Hi Everybody
I'm using AP7161 with FW WIng 5.8. How to block 1 client in the network?
Thanks you
Photo of Tuan Nguyen
Tuan Nguyen
  • 678 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Shay Weir
Shay Weir
  • 1,648 Points 1k badge 2x thumb
Create an association ACL and apply to SSID...
association-acl-policy CLIENT-BLACKLIST
deny xx-xx-xx-xx-xx-xx xx-xx-xx-xx-xx-xx precedence 1
permit 00-00-00-00-00-00 FF-FF-FF-FF-FF-FF precedence 1000
Photo of Bin
Bin, Employee
  • 5,370 Points 5k badge 2x thumb
You could configure MAC Firewall Rules to block the client.
1. Select Configuration > Security > Wireless Firewall > MAC Firewall Rules
2. Add new Row to create MAC firewall Rule to Deny the traffic
3. Apply the rule on WLAN
Best regards,
Photo of Shay Weir
Shay Weir
Use he CLI...
Tuan Nguyen
Thanks Say Weir, but  I'm pretty poor at using CLI, I often use more interfaces.
Photo of Shay Weir
Shay Weir
In the GUI...
Configuration Tab
Wireless tab
Association ACL - Create one to deny the MAC.  Be sure to do a permit at the end for all others (permit 00-00-00-00-00-00 FF-FF-FF-FF-FF-FF precedence 1000)
Once created...
WLAN Tab
select the SSID to apply ACL to
Expand the list of options for the WLAN
Select Firewall
then look for association ACL and enter the name of the ACL you created above to deny the MAC.  Apply and save.
How to do via GUI.....
I prefer to use the CLI as it is much quicker.  Download the Command reference guide for WiNG.  All CLI commands are there.  Very easy to use.
Good luck.
Tuan Nguyen
Hi you
I created MAC firewall rules but client still connection.  I try created IP Firewall rules but still not successful. Can you help me
Thank you
(Edited)
Photo of Prakash
Prakash
  • 60 Points
hey i need help... Please tell me how to disable client auto blocking in rfs7000 (WIPS ) ...
