How to change ip address in extreme switch
  • 2
  • Question
  • Updated 2 years ago
  • Answered
Photo of @ke
@ke
  • 162 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of André Herkenrath
André Herkenrath, Employee
  • 1,962 Points 1k badge 2x thumb
When your switch is factory default, it has no IP Address (unless you have a quite new release and the IP via DHCP)
Best practice is not to use the vlan default but to create a new one.
Here we go:
configure vlan default delete ports all
create vlan data tag 100
configure vlan data add ports all
configure vlan data ipadress 192.168.0.1/24
That's it
(Edited)
Photo of @ke
@ke
Now I'm Chang ip address.  " unconfigure vlan "Default" ipaddress "  next,  Configure vlan "Default" ipaddress xx.xx.xx.xx/xx.   I'm want to chang ip address. Do not delete IP Address.
Photo of M.Nees
M.Nees, Embassador
  • 9,414 Points 5k badge 2x thumb
The ip change is only possible via a delete and a assign new one. If you have only a network connection to this switch - do it with a script.
Photo of M.Nees
M.Nees, Embassador
Hi @ke,
i found a script how to change the switching ip automatically:
enable cli scripting
unconfigure "Default" ipaddress
configure "Default" ipaddress 10.1.1.200/24
# write script and via tftp to the switch
# or local via "edit script change-ip.xsf" (vi-like)
# ls
# X430-8p.14 # load script change-ip.xsf
# * X430-8p.15 #
Regards
