How to check, find out and resolve the root cause of HIGH CPU Utilization in more detail? What is Normal Utilization range 0-60 ???
  • Question
  • Updated 3 years ago
  • Answered
Slot-1 x250-sw# show cpu-monitoring
      CPU Utilization Statistics - Monitored every 20 seconds
Card   Process      5    10   30   1    5    30   1    Max           Total
                    secs secs secs min  mins mins hour            User/System
                    util util util util util util util util       CPU Usage
                    (%)  (%)  (%)  (%)   (%)  (%)  (%)  (%)         (secs)
Slot-1 System        n/a  n/a  0.0  0.3  0.1  0.1  0.2 43.8   612.90   261811.43
Slot-2 System        n/a  n/a  0.0  0.1  0.0  0.0  0.1 79.3     0.00       0.00
Thanks for any guidance,
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hi Paul,
Typically high CPU utilization needs to be diagnosed case by case. There are certain processes that can run high which will lead us towards certain diagnostics steps to find out what is causing the high CPU%. There really isn't a recommended range. Depending on what the switch is being used for some processes can spike for a very short period of time.
If you are seeing network problems or problems on the switch please check the "top" output. This will show you real time CPU usage. If you see some processes each running at maybe 10 or 20% I would recommend opening a case with GTAC so it can looked into further.
Thanks,
Patrick
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Here's a bit more on "Understanding the output of a Top command" from GTAC Knowledge.
Photo of Paul
Paul
Thank you Partick and Ryan, i will look into it to get more understand on this portion.
-Paul
Photo of ChrisH
ChrisH, ESE - Employee
  • 350 Points 250 badge 2x thumb
I agree that the "top" command will provide better information on what process is running high..
in case that a process called bcmRX is going high, then this indicates that a lot of packets are being forwarded by software (the CPU) and not the switching hardware, and this often indicates either a loop in the network or full tables..
