How to check radar is enabled on C5210 Controller , how to disable radar if seen enabled on controller
  • Question
  • Updated 2 years ago
  • Answered
We are suspecting users on 5Ghz channel are facing dis connectivity issues, I was going through forums and found with Radar enabled on controller dis connectivity issues are observed.
And Also users are Jumping between radios on same AP every minute / two.
Access Points Model: 3805i
Controller & AP version: 9.21.10.0005
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Just click on RADAR (top/right) in the controller GUI.
If you want to disable it remove the checkmark for "Security Analysis Engine"
