How to check the non dot1x port in BD and is it possible to generate report
PARI_ELANSURIYA
New Contributor II
How to check the non dot1x port in BD and command to check and is it possible to generate report
1 REPLY 1
Karthik_Mohando
Hi Pari,
I would suggest to check the dot1x enabled port using the command "show configuration netlogin"
