How to config MPLS (isis,ospf,bgp) connect to Cisco
  • Question
  • Updated 3 years ago
Ex. Config Cisco have
•isis authentication mode md5
• isis authentication key-chain test
How to config  switch Extreme  connect key-chain ?
Photo of @ke
  • 162 Points 100 badge 2x thumb
Posted 3 years ago
  • 4,362 Points 4k badge 2x thumb
Whats the switch model number
And exos version you are using
I need yo check
Based on that
Photo of @ke
Model Number :17103 Summit X670-48x-FB
MPLS Number :17133 Summit X670 MPLS Feature Pack 1
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 11,948 Points 10k badge 2x thumb
md5 authentication for ISIS is not supported on EXOS.
The topic name is "How to config MPLS". For that, the User Guide should be a good resource to see all the various features we are supporting and the one you need in your specific case:
In general, think of an interface as a vlan with one port.
  • 382 Points 250 badge 2x thumb
If you using IS-IS for MPLS, EXOS is not supported for md5 authentication but you could change configuration on cisco by using clear-text in key-chain instead md5.
for example, I assume you use "no switchport" in cisco for L3
cisco(config)#key chain xxx
cisco(config-keychain)#key [number]
cisco(config-keychain-key)#key-string [text]  <<< in these key-string  you couldn't use mode 7 for hidden password.
After you setting key chain, you could enable isis authentication in yours interface by,
cisco(config)#interface XX0/x
cisco(config-int)isis authentication mode text
cisco(config-int)isis authentication key-chain xxx
          ---Done for Cisco---
from now, you go to EXOS and config IS-IS by,
X670#config isis vlan <vlan_name> password simple <same text as cisco key-string> level-1          ---Done for EXOS---
Let's try and report, pls.
