How to configure a port of the switch SummitX-150 to connect a vmware infrastructure with several machines on differents VLANs
  • Question
  • Updated 2 years ago
  • Answered
I'm configuring a switch Extreme SummitX-150 Port to connect an ESXi platform on its port linked to a vswitch. the vswitch has several VMs on differents vlans. How to configure the Switch Port? Previously the switch used was a cisco 2960 and the configuration we used was
switchport mode trunk
switchport trunk native vlan [MAN_vlan]
switchport trunk allowed vlan [list of the vlans whose traffics will be enabled on this port]
Photo of AIT Support
AIT Support
  • 150 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 44,984 Points 20k badge 2x thumb
please refer to this post for the XOS commands of a trunk port...
https://community.extremenetworks.com/extreme/topics/trunking_port
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Ait Support,
To simplify tagging on EXOS the native vlan is the untagged vlan. If you are adding more then one vlan to a port then it is considered a trunk port. Only one vlan can be added to a port as untagged. The equivalent configuration would be this:
switchport trunk allowed vlan [list of the vlans whose traffics will be enabled on this port] \
to:
configure vlan MAN_vlan add port <port#> untagged
configure VLAN [list of the VLANs whose traffics will be enabled on this port] add port <port#> tagged
Continue the second command until the port has been added into each VLAN individually. On some newer versions of EXOS you can put in a VLAN id list using the tag given to that VLAN
Hope this helps!
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
