How to configure ap4511 captive portal where user (no authentication) will disconnect after 1 hour.
  • Question
  • Updated 3 years ago
  • Answered
captive portal where user will disconnect after 1 hour. no authentication
Photo of Marlon
Marlon
  • 1,570 Points 1k badge 2x thumb
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
This is normal guest user configuration
Where for a captive portal user you configure
The username and password with timings .
Example you can set the username active timing between 9:00 am to 5:00 pm or in number of hours
use this guide as a reference
https://www.dropbox.com/s/4kb5p5rl1ycxakl/SVC%20Tech%20Implementation%20Guide%20WM3000%20Series%20SW...
and you need to add guest users in controller.
