How to configure EAPS primary or secondary port, if this port belong to a LAG?
  • Question
  • Updated 3 years ago
  • Answered
Hi, I'm doing a test lab, and I want to make a LAG to participate ein a EAPS domain and I noticed that you can put many ports  as primary or secondary, so I was wondering if I have to put all the ports that belong to the LAG or I only put the master port,In case its only necessary to put the master port what is the purpose of the command to put a list port.  Thanks in advance.
Photo of Edison
Edison
  • 512 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Eric Burke
Eric Burke
  • 3,500 Points 3k badge 2x thumb
Once you set up sharing, you only need to add the master port to the EAPS config.  For example, I have a client where we're running LACP on 1:47 and 2:47 as well as another on 1:48 and 2:48 (the 1: switches are the master ports).  My Eaps config is pretty simple:
create eaps EapsCampusRing1
config eaps EapsCampusRing1 mode master
config EapsCampusRing1 primary port 1:47
config EapsCampusRing1 secondary port 1:48
config EapsCampusRing1 add control vlan V4001-EapsCampusCtrl1
config EapsCampusRing1 add protected vlan default
config EapsCampusRing1 add protected vlan V10-Lan1
config EapsCampusRing1 add protected vlan V11-LegacyLan1
config EapsCampusRing1 add protected vlan V60-WifiPrivate1
config EapsCampusRing1 add protected vlan V67-WifiProvis1
config EapsCampusRing1 add protected vlan V68-WifiGuest1
config EapsCampusRing1 add protected vlan V70-Voip1
config EapsCampusRing1 add protected vlan V79-Backup1
enable eaps
enable EapsCampusRing1
Eric
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
You only have to put the master port into either the primary of secondary ports.  Not sure about the list as you call it as you can only have one master and one secondary port.
Photo of Edison
Edison
Thank you Erik and Bill, I will test it in a lab next week.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Thanks for joining the Hub Dennis.
As you can see, answers flow fast in our Community.  Give a little and you get a lot in return!
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,076 Points 5k badge 2x thumb
Dennis,  Let us know how the lab goes.
