How to configure Extreme switches to securCRT ?
  • Problem
  • Updated 2 weeks ago
  • Solved
I'm trying to configure extreme switches parameters from GNS3 to securCRT but it dosn,t connect!
Photo of Mohamed Karamalla
Mohamed Karamalla
  • 84 Points 75 badge 2x thumb
Posted 2 weeks ago
Photo of Frank
Frank
  • 3,836 Points 3k badge 2x thumb
I assume that you can ping the switch's IP address from your workstation.
Did you "enable ssh2" either globally or just for the appropriate VR?
In the SSH2 configuration in SecureCRT, I have "Password" first, followed by all the other options - that way "password" gets attempted first.
You may (in SecureCRT) have to enable additional "Key exchange" options (SSH2 section) or/and additional Ciphers and MAC options (SSH2->Advanced in SecureCRT)
On 'older' XOS versions, you have to install ssh as an additional module (something-ssh.xmod, if I recall correctly) for the appropriate OS. I think it's bundled since 16.x, not sure what the first 20-something version was that had bundled ssh support.
Hope that helps,
   Frank
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,632 Points 3k badge 2x thumb
Good response, Frank. I just want to add that 16.2 and 21.1 were the versions where the SSH xmod is built into the EXOS image.
Brad
Mohamed Karamalla
Very helpful .. I'll try thanks frank
