How to configure voice and data vlan on the same 200 series switch
  • Question
  • Updated 2 months ago
  • Answered
Hi Team,
we have 2 VLANs for voice and data, we need to access both VLAN on the same 200 series switch port.
what are the procedures to configure the switch port?
Photo of Niyas
Niyas
  • 688 Points 500 badge 2x thumb
Posted 2 months ago
Photo of Ignace Vyncke
Ignace Vyncke
  • 210 Points 100 badge 2x thumb
Hello Niyas,
you need to untagg the ports for data vlan, and tagg the ports for voice vlan.
the voice end point needs to send the vlan id. If you use the 210 serie, then you need a additional L3 device (firewall, router) to route between the 2 vlan's, if you use the 220 serie, this is a L3 switch and can route between the two vlan's.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,528 Points 20k badge 2x thumb
Photo of Niyas
Niyas
Thanks for your updates
Photo of Niyas
Niyas
1.  Enter config
(Extreme 220) #config
2.  Enter port config mode
(Extreme 220) (Config)#interface 1/0/2
3.  Configure the following
(Extreme 220) (Interface 1/0/2)#voice vlan 110
(Extreme 220) (Interface 1/0/2)#switchport mode access
 (Interface 1/0/2)#switchport access vlan 10
(Interface 1/0/2)#switchport trunk native vlan 10
 (Interface 1/0/2)#switchport trunk allowed vlan 110
 (Interface 1/0/2)#exit
This is correct or not?
no need for "switchport access vlan 10" because you configure it with "switchport trunk native vlan 10"
Photo of Niyas
Niyas
Hi Ronald
I have already configured, need to remove Switchport access VLAN 10?
