How to configure VPLS L2VPN Pseudo Wire with MPLS
  • Question
  • Updated 3 years ago
  • Answered
Hello, I'm needing some help setting up a layer 2 vpn between two X460-24t across a wan. I have all the necessary licensing and feature packs installed. The wan used static routing and is 3 hops away, also the routers in between do not participate in the MPLS. I've started setting up the MPLS and VPLS here's where I'm at...What am I doing wrong?
Switch #1 name ldc-xm0-nsw012
ldc-xm0-nsw012.19 # sh vlan
Name            VID  Protocol Addr       Flags                         Proto  Ports  Virtual
        Active router
        /Total
Default         1    ------------------------------------------------- ANY    0 /0   VR-Default
ent_sp0-int001  3151 209.249.151.250/24  ---------------------V------- ANY    1 /2   VR-Default
lpbk            4094 192.168.0.1    /32  -fL------------------l------- ANY    0 /0   VR-Default
Mgmt            4095 10.55.211.20   /24  ----------------------------- ANY    1 /1   VR-Mgmt
snj_si0-bkd022  3155 172.31.55.2    /24  -f-------------------l------- ANY    2 /2   VR-Default
ldc-xm0-nsw012.19 # sh ipr
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#s   172.31.22.0/24     172.31.55.251   1    UG---S-um--f- snj_si0-bkd022 4d:21h:25m:29s
#d   172.31.55.0/24     172.31.55.2     1    U------um--f- snj_si0-bkd022 4d:21h:26m:52s
#d   192.168.0.1/32     192.168.0.1     1    U------um--f- lpbk       4d:20h:11m:46s
#d   209.249.151.0/24   209.249.151.250 1    U------um--f- ent_sp0-int001 4d:21h:48m:51s
ldc-xm0-nsw012.20 # sh conf mpls
# Module mpls configuration.
configure mpls add vlan "lpbk"
enable mpls vlan "lpbk"
enable mpls ldp vlan "lpbk"
configure mpls add vlan "snj_si0-bkd022"
enable mpls vlan "snj_si0-bkd022"
enable mpls ldp vlan "snj_si0-bkd022"
configure mpls lsr-id 172.31.55.2
enable mpls protocol ldp
enable mpls
create l2vpn vpls ldc-snj-vpn fec-id-type pseudo-wire 25
configure l2vpn vpls ldc-snj-vpn add service vlan ent_sp0-int001
configure l2vpn vpls ldc-snj-vpn add peer 172.31.22.2 core full-mesh
ldc-xm0-nsw012.21 # sh vpls detail
L2VPN Name: ldc-snj-vpn
   VPN ID                : 25                    Admin State   : Enabled
   Source Address        : 172.31.55.2           Oper State    : Enabled
   VCCV Status           : Disabled              MTU           : 1500
   VCCV Interval Time    : 5 sec.                Ethertype     : 0x8100
   VCCV Fault Multiplier : 4                     .1q tag       : exclude
   L2VPN Type            : VPLS                  Redundancy    : None
   Service Interface     : ent_sp0-int001
   Created By            : CLI
   Peer IP: 172.31.22.2
      PW State           : Signaling (No transport LSP)
      PW Index           : 10002
      PW Signaling       : LDP
      PW Uptime          : 0d:0h:0m:0s
      PW Installed       : False
      Local PW Status    : Not Signaled
      Remote PW Status   : Not Signaled
      Remote I/F MTU     : 1500
      PW Mode            : Core-to-Core
      PW Rx Label        : 0x00434                PW Tx Label  : 0x00434
      PW Rx Pkts         : --                     PW Tx Pkts   : 0
      PW Rx Bytes        : --                     PW Tx Bytes  : 0
      MAC Limit          : No Limit
      VCCV HC Status     : Not Sending (VCCV Not Enabled For This L2VPN)
         CC Type         : Rtr Alert           Total Pkts Sent : 0
         CV Type         : LSP Ping            Total Pkts Rcvd : 0
         Send Next Pkt   : --
         Total Failures  : 0          Pkts During Last Failure : 0
         Last Failure Tm : --
Total number of configured L2VPNs:    1
Total number of active L2VPNs:        0
Total number of configured PWs:       1
Total number of active PWs:           0
Total number of ready PWs:            0
PWs auto-selecting transport LSP:     0
PWs configured with a transport LSP:  0
PWs using LDP for transport:          0
PWs using RSVP for transport:         0
PWs using static for transport:       0
ldc-xm0-nsw012.22 # traceroute 172.31.22.2
traceroute to 172.31.22.2, 30 hops max
 1  172.31.55.251                                2 ms        1 ms        1 ms
 2  172.31.254.13                               42 ms       41 ms       41 ms
 3  172.31.22.2                                 41 ms       42 ms       41 ms
Switch #2 name snj-xm0-nsw010
snj-xm0-nsw010.11 # sh vlan
        Active router
        /Total
ent_sp0-int001  3151 209.249.151.251/24  ---------------------V------- ANY    1 /2   VR-Default
Mgmt            4095 10.22.211.30   /24  ----------------------------- ANY    1 /1   VR-Mgmt
snj_si0-bkd022  3155 172.31.22.2    /24  -f-------------------l------- ANY    2 /2   VR-Default
snj-xm0-nsw010.12 # sh ipr
#d   172.31.22.0/24     172.31.22.2     1    U------um--f- snj_si0-bkd022 4d:21h:22m:22s
#s   172.31.55.0/24     172.31.22.251   1    UG---S-um--f- snj_si0-bkd022 4d:21h:21m:17s
#d   192.168.0.1/32     192.168.0.1     1    U------um--f- lpbk       4d:20h:16m:7s
#d   209.249.151.0/24   209.249.151.251 1    U------um--f- ent_sp0-int001 4d:22h:38m:46s
snj-xm0-nsw010.13 # sh conf mpls
configure mpls lsr-id 172.31.22.2
enable mpls
configure l2vpn vpls ldc-snj-vpn add peer 172.31.55.2 core full-mesh
snj-xm0-nsw010.14 # sh vpls detail
   Source Address        : 172.31.22.2           Oper State    : Enabled
   Created By            : CLI
   Peer IP: 172.31.55.2
      PW Index           : 10002
      PW Signaling       : LDP
         Send Next Pkt   : --
snj-xm0-nsw010.15 # traceroute 172.31.55.2
traceroute to 172.31.55.2, 30 hops max
 1  172.31.22.251                                2 ms        1 ms        6 ms
 2  172.31.254.45                               42 ms       42 ms       42 ms
 3  172.31.55.2                                 42 ms       42 ms       41 ms
Photo of Matt Tinonga
Matt Tinonga
  • 372 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Andrew Maldonado
Andrew Maldonado, Extreme Alumnus
  • 2,302 Points 2k badge 2x thumb
Matt,
Is the MPLS LDP session between the two VPLS endpoints in the operational state? The command to view the LDP sessions is "show mpls ldp peer". Also, which software version are the Summit X460 switches running?
-Andrew
Matt Tinonga
snj-xm0-nsw010.2 # show mpls ldp peer
IP Address      LDP Peer             State        Uptime          Adjacencies
172.31.22.2     172.31.55.2:0        Operational  0d:22h:15m:26s      1
ldc-xm0-nsw012.4 # show mpls ldp peer
172.31.55.2     172.31.22.2:0        Operational  0d:22h:16m:2s       1
Both switches are running ExtremeXOS version 15.7.1.4 v1571b4-patch1-2
Photo of andreas
andreas
  • 1,218 Points 1k badge 2x thumb
Ldp is multicast based. Not sure if extremes support tldp. ?
Andreas,
The LDP hello packets are indeed transmitted via multicast to all routers (224.0.0.2) but the session is established via unicast.
LDP is supported on select platforms, with the Summit X460 being one of them. We can see in the configuration provided in the body of the post that LDP is enabled.
-Andrew
Photo of andreas
andreas
Well then you need multicast routing on the routers between the ldp nodes ?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,346 Points 10k badge 2x thumb
Are you saying there's no MPLS on the routers in-between your routers?
Matt Tinonga
Correct.
So you're sending an MPLS frame to non-MPLS capable routers? How do you plan to setup an MPLS LSP? Am I missing something here?
Matt Tinonga
The end points will be MPLS routes but the in between routes will not. It was my understanding that the in between router would pass the MPLS traffic. If you read below you will see the LDP peers are operational. But vpls l2vpn shows in a signeling state and does not coma active. Thanks for any HELP!
Sorry for not following closely this thread (vacations...). The Targeted LDP adjacency can come Up across an IP backbone, no problem, but the transport is impossible without MPLS LSP in the backbone. I'm afraid you're trying to do something not possible.
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Matt,
The LSR ID of the MPLS routers should be a routed loopback address(/32 and loopback enabled). In your case, the LSR ID should be of the VLAN which is lpbk since it has a /32 address.
Following are the changes that is required.
configure mpls lsr-id 192.168.0.1
enable mpls
configure l2vpn vpls ldc-snj-vpn add peer 192.168.0.2 core full-mesh
You will need to change the lpbk VLAN address to a different IP say 192.168.0.2.
configure mpls lsr-id 192.168.0.2
enable mpls
configure l2vpn vpls ldc-snj-vpn add peer 192.168.0.1 core full-mesh
Please make this change and let us know if it helps!
Matt Tinonga
Thanks Prashanth. I found two issues with my config. I did not have routing between the loopback and a vlan tag was incorrect.  I've made the change you recommend and fix the routing issue and vlan tag, I did use diffrent IP for the loppback to better fit into our network.
I do see the end points operational.
snj-xm0-nsw010.7 # sh mpls ldp peer
192.168.122.1   192.168.155.1:0      Operational  0d:0h:27m:22s       1
192.168.155.1   192.168.122.1:0      Operational  0d:0h:27m:12s       1
But I'm still seeing vpn showing Signaling state.
snj-xm0-nsw010.10 # sh vpls "ldc-snj-l2vpn" detail
L2VPN Name: ldc-snj-l2vpn
   VPN ID                : 3125                  Admin State   : Enabled
   Source Address        : 192.168.122.1         Oper State    : Enabled
   Created By            : CLI
   Peer IP: 192.168.155.1
      PW Index           : 10001
      PW Signaling       : LDP
      PW Rx Label        : 0x00435                PW Tx Label  : 0x00435
         Send Next Pkt   : --
ldc-xm0-nsw012.4 # sh mpls ldp peer
ldc-xm0-nsw012.5 # sh vpls "ldc-snj-l2vpn" detail
   Source Address        : 192.168.155.1         Oper State    : Enabled
   Created By            : CLI
   Peer IP: 192.168.122.1
      PW Index           : 10001
      PW Signaling       : LDP
         Send Next Pkt   : --
snj-xm0-nsw010.11 # sh config mpls
configure mpls lsr-id 192.168.122.1
enable mpls
create l2vpn vpls ldc-snj-l2vpn fec-id-type pseudo-wire 3125
configure l2vpn vpls ldc-snj-l2vpn add service vlan ent_sp0-int001
configure l2vpn vpls ldc-snj-l2vpn add peer 192.168.155.1 core full-mesh
snj-xm0-nsw010.12 # sh config ospf
# Module ospf configuration.
configure ospf routerid 192.168.122.1
enable ospf
enable ospf export direct cost 10 type ase-type-1
configure ospf add vlan lpbk area 0.0.0.0
configure ospf add vlan snj_si0-bkd022 area 0.0.0.0
ldc-xm0-nsw012.6 # sh conf mpls
configure mpls add vlan "ldc-si0-bkd55"
enable mpls vlan "ldc-si0-bkd55"
enable mpls ldp vlan "ldc-si0-bkd55"
configure mpls lsr-id 192.168.155.1
enable mpls
configure l2vpn vpls ldc-snj-l2vpn add peer 192.168.122.1 core full-mesh
ldc-xm0-nsw012.7 # sh conf ospf
configure ospf routerid 192.168.155.1
enable ospf
configure ospf add vlan ldc-si0-bkd55 area 0.0.0.0
Your help is much appreciated!
Hi Matt,
Good to know that some misconfigs have been sorted out.
If the MPLS peers are operational, there should be a transport LSP for the peer automatically in the VPLS instance. Try re-configuring the L2VPN and check if it helps!
Also, please refer the article below for a sample VPLS configuration.
How to configure VPLS session in Extreme Switches using LDP
Hope this helps!
Matt Tinonga
Hi Prashanth, thank you again... I've stripped the configuration out of MPLS & LDP & OSPF and started over again and used you doc "How to configure VPLS session in Extreme Switches using LDP".  I've triple checked the confing and I'll still getting to the same point "Signaling (No transport LSP)".
* snj-xm0-nsw010.61 # show vpls
L2VPN Name      VPN ID Flags   Services Name   Peer IP         State Flags
vpls-snj-bkd022 100    EAX--L- ent_sp0-int001  192.168.155.1   Sgnl  C---V-L
I did notice when getting to the 2nd part of step (d.) when I rain the command "show mpls ldp peer" it returned nothing on both switches. Not until I added the last command "configure l2vpn vpls vpls-snj-bkd022 add peer 192.168.155.1 core full-mesh" did I get a responce.
* snj-xm0-nsw010.60 # show mpls ldp peer
192.168.122.1   192.168.155.1:0      Operational  0d:0h:41m:47s       1
configure l2vpn vpls vpls-ldc-bkd55 add peer 192.168.122.1 core full-mesh
* ldc-xm0-nsw012.39 # show mpls ldp peer
192.168.155.1   192.168.122.1:0      Operational  0d:0h:42m:21s       1
OSPF is advertiseing the routes and I can get ping from both end points.
* snj-xm0-nsw010.1 # sh ipr
#d   172.31.22.0/24     172.31.22.2     1    U------um--f- snj_si0-bkd022 0d:23h:5m:59s
#oa  172.31.30.0/24     172.31.22.251   12   UG-D---um--f- snj_si0-bkd022 0d:3h:22m:13s
#oa  172.31.55.0/24     172.31.22.251   12   UG-D---um--f- snj_si0-bkd022 0d:3h:22m:13s
#d   192.168.122.1/32   192.168.122.1   1    U------um--f- lpbk       0d:23h:5m:59s
#oa  192.168.155.1/32   172.31.22.251   22   UG-D---um--f- snj_si0-bkd022 0d:3h:22m:13s
snj-xm0-nsw010.3 # ping 192.168.155.1 from 192.168.122.1
Ping(ICMP) 192.168.155.1: 4 packets, 8 data bytes, interval 1 second(s).
16 bytes from 192.168.155.1: icmp_seq=0 ttl=62 time=42 ms
16 bytes from 192.168.155.1: icmp_seq=1 ttl=62 time=41 ms
16 bytes from 192.168.155.1: icmp_seq=2 ttl=62 time=41 ms
16 bytes from 192.168.155.1: icmp_seq=3 ttl=62 time=44 ms
I've copied the configs from both switches in the format of your document link.
Do you have any other ideia? or any test I can run?
Switch #1: snj-xm0-nsw010
loopback vlan name:    lpbk (192.168.122.1/32)
Core vlan name:        snj_si0-bkd022 (172.31.22.2/24)
Service vlan name:    ent_sp0-int001
VPLS l2vpn name:    vpls-snj-bkd022
create vlan "ent_sp0-int001"
configure vlan ent_sp0-int001 tag 3151
create vlan "lpbk"
enable loopback-mode vlan lpbk
create vlan "snj_si0-bkd022"
configure vlan snj_si0-bkd022 tag 3122
configure vlan snj_si0-bkd022 ipaddress 172.31.22.2 255.255.255.0
enable ipforwarding vlan snj_si0-bkd022
configure vlan lpbk ipaddress 192.168.122.1 255.255.255.255
enable ipforwarding vlan lpbk
disable igmp snooping vlan "ent_sp0-int001"
enable ospf
configure ospf add vlan lpbk area 0.0.0.0 passive
enable mpls
create l2vpn vpls vpls-snj-bkd022 fec-id-type pseudo-wire 100
configure l2vpn vpls vpls-snj-bkd022 add service vlan ent_sp0-int001
Switch #2 ldc-xm0-nsw012
loopback vlan name:    lpbk (192.168.155.1/32)
Core vlan name:        snj_si0-bkd022 (172.31.55.2/24)
VPLS l2vpn name:    vpls-ldc-bkd055
create vlan "ldc-si0-bkd55"
configure vlan ldc-si0-bkd55 tag 3155
create vlan "lpbk"
configure vlan ldc-si0-bkd55 ipaddress 172.31.55.2 255.255.255.0
enable ipforwarding vlan ldc-si0-bkd55
configure vlan lpbk ipaddress 192.168.155.1 255.255.255.255
enable ospf
enable mpls
create l2vpn vpls vpls-ldc-bkd55 fec-id-type pseudo-wire 100
configure l2vpn vpls vpls-ldc-bkd55 add service vlan ent_sp0-int001
Hi Matt,
The configuration part looks fine to me for both the peers. Looking at the iproute output, I get an impression that there are other routers in the path. Can you confirm that? Are these devices running MPLS too? We may not have the proper LSPs for every next-hop. may be that is why, the signaling is not active.
if these are third party devices, is it possible to configure the MPLS on these devices and check if that helps!
Matt Tinonga
Hi Prashanth, see my reply in the string below... thanks again for your help.
Matt Tinonga
Hi Prashanth, yes there is routers in between there are X450a with only Advanced Edge licening so I can't enable MPLS. I would think that the X450a would pass the MPLS traffic? Is there something that would stop them from doing so?
Thanks again, Matt
Matt Tinonga
Prashanth, I wonted to add that was checking the advertising of each of the routers. I'm seeing a diffrence on the two routes.
snj-xm0-nsw010.8 # sh mpls ldp label advertised
Advertised     Destination  Label     Peer  NHop
Label              Mapping  Flags    Label  Type  NextHop            Name
0x00434   192.168.122.1/32    -LE       --  vlan  lpbk               --
0x00435   192.168.155.1/32    2LE       --  VPLS  --                 vpls-snj-bkd022
Flags: (3) L3VPN, (2) L2VPN, (L) LDP, (R) RSVP-TE, (S) Static,
       (T) Transit LSP, (I) Ingress to LSP, (E) Egress from LSP,
       (M) Multiple Next Hops
ldc-xm0-nsw012.9 # sh mpls ldp label advertised
0x00434   192.168.122.1/32    2LE       --  VPLS  --                 vpls-ldc-bkd55
Is this some ting to look into?
Thanks Matt
Photo of EtherMAN
EtherMAN, Embassador
  • 6,960 Points 5k badge 2x thumb
Hmm not a MPLS expert but when we need to pass MPLS framing at layer 2 across a non-mpls switch then we build a vman and enable jumbo frames on the per layer 2 switches to tunnel the mpls traffic through.  On the 450's there are some restrictions if you want to pass standard tagged vlans and vmans on common trunk ports.  Not sure if this will help or confuse
Matt Tinonga
Thanks, one limitation is that I can not enable jumbo packets the the wan link does not support jumbo packets.
