how to connect extreme switch to a another switch
  • Question
  • Updated 2 years ago
  • Answered
What I am trying to do I am not sure if it is even possible, I am trying to setup a testing lab in my house to have 2 vm host running server 2012 on to different subnets
so this is how I want to set this up if possible and please tell me if it is not
Coming from my modem plugged into pfsense firewall running 192.168.20.2 on the lan side
From the firewall plugs into my Extreme switch x250e switch all untagged ports from here to my vm host
my server 2012 r2 is setup as a domain controller, DHCP, and DNS on 192.168.20.1/24 this is all working fine ,
The problem is I have another switch that is a Dell power connect that is running another vm host
On this server 2012 r2 is setup as Domain Controller, DHCP, and DNS running ip range 192.168.30.1/24
Is there a way to connect the Extreme switch to the Dell switch to pass traffic back and fourth on both subnets so I can access any other servers or clients on either subnet and Have internet running on both subnets running with 1 modem and firewall
Any help would be great
Photo of Adam longtin
Adam longtin
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of simon bingham
simon bingham
  • 1,206 Points 1k badge 2x thumb
1) using pen and paper sketch your requirement, it is convention to have the default gateways as .1 or .254
2) if you have a vmware server and it has different networks internaly you will need to have a tagged link running to your server ( this can carry multiple subnets on the same link ) I cannot help with this. look at vswitches and tagging
save # save config so you get back to where you where by rebooting
create vlan v20 tag 20
create vlan v30 tag 30
configure vlan v20 ipaddress 192.168.20.254/24
configure vlan v30 ipaddress 192.168.30.254/24
enable ipforwarding v20
enable ipforwarding v30
config default delete ports all
config vlan v20 add port all untagged
config vlan v30 add port 10 tagged # port 10 to vmware server
configure iproute add default  192.168.20.2
you home router will need to route to
192.168.30.0/24 next hop 192.168.20.254
this config probably has typos
many home routers  ( netgear and the type ) don't support multiple internal networks
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,568 Points 5k badge 2x thumb
I believe the best approach is described by Simon = you will have two subnets, each subnet does have own vlan. You need to route the traffic between those subnets. Summit can do routing for you or your firewall can do it. If you have both subnets on both servers then You will need to configure vlans on both switches.
If you have one subnet per server then you will need only secondary IP address on the interface.
The drawing would help here.
Adam longtin
here is a very simple sketch of what i have and trying to setup
Adam longtin
So with the pic I have uploaded will I still use these commands to do this create vlan v20 tag 20
Also I dont have a home router I have a all in one modem from comcast with a static ip going to pfsense
Adam longtin
ok i added these vlans and all the commands provided but they are still not comunicating with each other. The first subnet 192.168.20.1/24 works fine and will not talk to 192.168.30.1/24
DO I need to add anything to the Dell switch or no
Adam longtin
Ok so I added the vlans to the xtreme switch and the ipforwards I have my second switch at default settings still no connection between the 2 subnets also I just want to say I am very new to setting this kind of network up so if I am asking very dumb question I just don't know how to get this configured properly and am looking for some help. Thanks for all the help
Photo of Drew C.
Drew C., Community Manager
  • 39,124 Points 20k badge 2x thumb
Hi Adam,
Take a look at my post in this thread to see if it helps explain things any better: https://community.extremenetworks.com/extreme/topics/iproute-if-only-using-l2
