in our environment we are using x460 layer3 switch its connected to firewall
firewall-->coreswitch is pinging
core--> layer 2 switch--> not pinging firewall ip, and vlan ip
firewall IP: X.X.10.200/24
X460 configuration
sh con
X460G2-24t-G4.86 # sh configuration
# Module devmgr configuration.
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-34
configure vr VR-Default add ports 1-34
configure vlan default delete ports 7
create vlan "one
configure vlan one tag 13
create vlan "two"
configure vlan "two" tag 14
configure ports 33 auto off speed 10000 duplex full
configure ports 34 auto off speed 10000 duplex full
configure vlan Default add ports 1-6, 8-34 untagged
onfigure vlan one add ports 16-24 tagged
configure vlan one add ports 7 untagged
configure vlan Default ipaddress X.X.10.201 255.255.255.0
configure vlan one ipaddress X.X.13.200 255.255.255.0
enable ipforwarding vlan one
configure vlan two ipaddress X.X.14.200 255.255.255.0
enable ipforwarding vlan two
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add X.X..13.0 255.255.255.0 X.X.10.200
configure iproute add default X.X.10.200
# Module mcmgr configuration.
# Module aaa configuration.
# Module acl configuration.
layer 2 210 switch
configuration
network protocol none
network parms X.X.10.206 X.X.X.X.0 X.X.10.201
vlan database
vlan 13-14
vlan name 13 "one"
vlan name 14 "two"
vlan routing 13 1
vlan routing 14 2
vlan routing 1 3
exit
X460 configuration
sh con
create vlan "one
create vlan "two"
layer 2 210 switch
configuration
vlan database
vlan 13-14
vlan name 13 "one"
vlan name 14 "two"
vlan routing 13 1
vlan routing 14 2
vlan routing 1 3
exit
