How to create an LACP LAG on EXOS 21.1X?
  • 2
  • Question
  • Updated 2 weeks ago
  • Answered
I'd like to create a simple 4 port LAG between an Extreme Switch (x460-G2) and a Brocade switch (that is already successfully setup for LACP)
I've never setup a LACP LAG on EXOS before.   Is there a guide for this?
Photo of Sean Scarfo
Sean Scarfo
  • 134 Points 100 badge 2x thumb
  • frustrated
Posted 2 weeks ago
  • 2
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,194 Points 10k badge 2x thumb
Hello Sean,
You follow the same procedure to create a lag and add "LACP" onto the end. Here is an article that shows this process:
Hope this helps!
Photo of Brian Austin
Brian Austin, Employee
  • 392 Points 250 badge 2x thumb
you can do this with the following command:
configure sharing <masterport> grouping <additional ports in lag> algorithm port-based lacp
additional information for this can be found here:
Photo of Bin
Bin, Employee
  • 5,128 Points 5k badge 2x thumb
Hi Sean,
Kindly share the good discussion about this topic in our Hub.
Best regards
