How to define Native Vlan to trunk port on voss VSP switches
  • 2
  • Question
  • Updated 5 days ago
  • Answered
Define Native Vlan on Voss
Photo of Erhan YILDIZ
Erhan YILDIZ
  • 346 Points 250 badge 2x thumb
Posted 5 days ago
  • 2
Erhan YILDIZ
Hello, I need a cli command to do that. Could not find anything on cli guide about native vlan.
Thanks,
Best Regards
Photo of Martin Sebek
Martin Sebek
  • 200 Points 100 badge 2x thumb
Hello,
in the port configuration you have to setup default vlan and enable untagging that vlan.
For example for vlan 10:
default-vlan-id 10
untag-port-default-vlan enable
Erhan YILDIZ
Hello Martin,
I couldn't test that for now but you are briallant.
Thanks,
Best Regards
Photo of Jongseok Won
Jongseok Won, Employee
  • 208 Points 100 badge 2x thumb
Hello, below is the Configuring the VLAN feature on a port using EDM.
1. On the Device Physical View tab, select a port or multiple ports.
2. In the Navigation tree, expand the following folders: Configuration > Edit > Port.
3. Click General.
4. Click the VLAN tab.
5. To perform tagging, select PerformTagging.
6. To discard tagged frames, select DiscardTaggedFrames.
7. To discard untagged frames, select DiscardUntaggedFrames.
8. To use the Untag Default VLAN feature, select UntagDefaultVlan.
Important:
Extreme recommends that you enable tagging on the port before you configure
UntagDefaultVlans.
9. Enter a default VLAN ID.
10. In the Classification area, select the types of VLAN to enable.
11. In the Classification area, select the Private VLAN port type. See Creating a private
VLAN on page 69 for more information.
12. Click Apply.
13. Click Close.
