How to delete a VLAN in S4 Chasis ?
  • Question
  • Updated 3 years ago
  • Answered
May be this is a basic question. But I could not find any reasoanble command to delete a VLAN in S4 Chassis..
Thank you very much in advance.
Photo of Weda
Weda
  • 994 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Tyler Marcotte
Tyler Marcotte, Official Rep
  • 2,784 Points 2k badge 2x thumb
Weda,
Here's an example of creating a vlan, naming it, and then deleting it. Hopefully this helps:
SSA180(su)->set vlan create 432
SSA180(su)->set vlan name 432 TestVlan432
SSA180(su)->clear vlan 432 ?
  modify-pvid                  Reset any PVIDs associated with deleted VLAN(s)
                               back to 1
  <cr>
SSA180(su)->clear vlan 432?
                               back to 1
  <cr>
SSA180(su)->
Tyler
Photo of Weda
Weda
Thanks for your reply. but this exactly how I was trying. This removes ports and VLAN name. but  if you issue "show vlan", it still appears. What do you think ?
Photo of Mike D
Mike D, Alum
  • 3,852 Points 3k badge 2x thumb
Hello Weda,
Take a look the the L3 vlan int's.
I think it's "no int vlan..."
Mike
Photo of Weda
Weda
 As I had implemented Vlan interface IP,
no int vlan  + clear vlan   commands did the job.
