How to disable inter vlan routing in AP7522E? In this firmware is 5.8.5.0-016R
  • 2
  • Question
  • Updated 1 year ago
  • Answered
Photo of Saravanamurthy K
Saravanamurthy K
  • 966 Points 500 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
 Saravanamurthy,
  •  Select the Configuration tab from the Web UI.
  •  Go to Devices
  •  Select System Profile from the options on the left hand side of Gui.
  •  Expand the Network menu and select Routing. The IPV4 routing tab displays by default.
  •  You could uncheck this "IP Routing" feature.
Please find the snippet below of the Network - Routing screen
Saravanamurthy K
ok. but Its not an Enterprise AP. its an express Model. How to go that Setup.
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,638 Points 5k badge 2x thumb
Saravanamurthy,
I am afraid this is something you cannot easily disable as there is no option for that in Express GUI.
However, it is enabled in Express profiles
vx9000-E29E5E#show running-config profile ap7522 default-ap7522 include-factory
<omitted>
 ip routing
<omitted>
Only way would be to use customized startup configuration uploaded to the AP, but this is not recommended / supported as it may violate pre-configured Express objects.
Regards,
Ondrej
