How to discover network devices with Management Center 7?
  • Question
  • Updated 2 years ago
  • Answered
How do I discover my network devices with Management Center 7.0?  Older versions of NetSight Console had a feature in which I could define an IP address range, select a type of discovery (ICMP or SNMP), enter SNMP credentials to use and find every device within that IP address range that would respond.
The legacy apps, such as Console, are going to be deprecated, and are no longer supported.
How do I do this same task using Management Center?
Thanks, Jess
Photo of Jesse Ohlsson
Jesse Ohlsson
  • 670 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Nispel, Markus
Nispel, Markus, Employee
  • 212 Points 100 badge 2x thumb
Jess, you find this under network/devices/sites - it allows ranges, seed etc. compared to former versions you can also schedule it (recurring). sites allow you to discover and map to a hierarchy and then leverage ZTP+ to provide initial configuration. a series of steps are combined within the sites tabs
discovered devices show up in the network/discover tab
Hope this helps
Photo of Stephen Flaherty
Stephen Flaherty, Employee
  • 270 Points 250 badge 2x thumb
The Help documentations provide a good description of the steps.  At the large ? icon search 'checklist'  and select topic "Extreme Management Center Initial Configuration Checklist".
1.  Organize, add, and configure devices in Management Center.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,280 Points 20k badge 2x thumb
Thanks for the link but I'd need to say I'd never been able to find it by myself.... I've tried.
I've searched for "device discovery" which linked me to "how to discover a device" which was the help article for the legacy discovery tool and that didn't included a link to the new EMC GUI feature.
So looks like I'd need a help for the help :-)
thank you for the feedback.Ronald. As we migrate from the java clients to the web UI we also need to optimize the help to support this. Working on this for the next release of Extreme Management Center.
Photo of Murphy, Daniel
Murphy, Daniel, Employee
  • 632 Points 500 badge 2x thumb
7.0 Site Discover seed discover now supports (Extreme Discover Protocol (EDP) and LLDP, Also one can define a range to discover by subnet as well.
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,114 Points 5k badge 2x thumb
I have created this Knowledgbase article, free for customer input if you believe it is lacking. It's to cover the most basic aspects of discovery, and not all the permutations.
