How to Display Summit X400 Series LLDP Information onto Cisco IP 79xx series Web GUI
  • Question
  • Updated 2 years ago
  • Answered
We're migrating away from Cisco switches and onto the Summit X400 series switches.  We currently have Cisco IP Phones (7900 and 9900 series).  From the IP Phone web GUI on the Cisco switches, we were easily able to determine what switch, switch IP, and port a particular phone was plugged into.  This of course used CDP.  Now that we're all Extreme for switches, I'm trying to get the proper LLDP information of the Summit switches to display properly...
Here's a screenshot of the info that is shown in the Web GUI of the IP Phones:
I can get the following LLDP information by doing the following:
LLDP Neighbor Device ID:   configure snmp sysName <switch_name>
LLDP Neighbor Port:  configure port <port_number> display-string <port_number>
However, I cannot seem to find a spot to set the LLDP Neighbor IP Address line so the phones display the switch IP.
I'm still trying to figure out a way to have this information automatically filled in.  Not sure what the best approach is for that?  Script maybe?
Any ideas would be greatly appreciated.
Thank you.
Photo of Rory Schmitz
Rory Schmitz
  • 276 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,040 Points 5k badge 2x thumb
Hello Rory,
The below commands will enable the LLDP advertisement you're looking for.
conf lldp ports all advertise management-address system-name port-description
en lldp ports all
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,660 Points 1k badge 2x thumb
Hello,
please check that you have configured an IP on the Mgmt Vlan, this IP will be used for the LLDP management IP, or you will see an MAC address.
https://gtacknowledge.extremenetworks.com/articles/Q_A/EXOS-LLDP-neighbor-Mgmt-Addr-is-Mac-address-v...
Bastian is correct.  We should come out with a new feature this year that allows us to pick a VLAN as your LLDP advertised management-address.
Rory Schmitz
We do not have the IP set on the Management VLAN, Only the vlan interface, 98 in our case.  Let me do some testing and let you know the results.
From the last link Bastian provided, it has the following:
  • as vlan Mgmt is attached on VR-Mgmt as Virtual Router you can enter also the same IP from the VR-Default for the LLDP binding
Is this statement saying I can use the same IP on my Mgmt Vlan and the VLAN 98 Interfaces?  We're using VR-Default.
Rory Schmitz
I guess maybe I should ask what the proper command is to set the IP on VR-Mgmt so that the LLDP information is displayed?
hello,
that is correct, you can use the same IP from your vlan 98 on the Mgmt Interface as this is an other VR. The command should look like that:
configure vlan Mgmt ipaddress 10.131.213.227 255.255.255.0
Rory Schmitz
Thanks everyone.  I now have it working as expected.  I'll try and see if there are script options out there to help with ease of Management on these, but I believe this was everything I had to do to get a Cisco IP Phone working with LLDP and your help.  Maybe there's room for cleanup?
Anyways, here it is:
#Set Management IP (Can be same as Switch VLAN/IP)
conf vlan mgmt ipaddress <IP Address>
#Configure Port settings
configure lldp port <port number> advertise port-description
configure lldp port <port number> advertise system-name
configure lldp port <port number> advertise system-capabilities
configure lldp port <port number> advertise management-address
configure lldp port <port number> advertise vendor-specific dot3 mac-phy
configure lldp port <port number> advertise vendor-specific med capabilities
configure lldp port <port number> advertise vendor-specific med power-via-mdi
configure lldp port <port number> advertise vendor-specific dot1 port-protocol-vlan-id vlan <Voice_VLAN_Name>
configure lldp port <port number> advertise vendor-specific dot1 vlan-name vlan <Voice_VLAN_Name>
configure lldp port <port number> advertise vendor-specific med policy application voice vlan <Voice_VLAN_Name> dscp 46
# Additional port Configuration
enable diffserv examination port <port number>
disable dot1p examination port <port number>
configure ports <port number> display-string <port number>
Here's the final Web UI screenshot of one of my Cisco IP Phones:
Everything looks great.  I really appreciate all of your help.
