How to do a license upgrade from Edge to Core license in Summit X460-48T switches?
  • Question
  • Updated 2 years ago
  • Answered
Hi experts,
I have a couple of switches Summit X460-48T, it was ordered for them the Core License. My doubt is if this Core Licence is already included in the equipments or if I have to download the license and perfoms the license upgrade in both equipments ( one time that the License Standard for the Summit X460-48T is the Edge License according with Extreme Documentation)
I case of to do the upgrade license, which information of the switches I need to download the Core License ?
And where Can I download this license ?
I hope had been clear .
Tks a lot
Photo of Rafael Neves
Rafael Neves
  • 70 Points
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Rafael,
The Article below might help:
How to generate and enable an EXOS license key
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,420 Points 3k badge 2x thumb
Hi Rafael,
You can confirm if a switch has a license by running the 'show license' command. To issue a license for the switches, we will need a voucher number (generated when purchasing the license) and the switch serial number. Henrique's article will guide you through the process.
Photo of Rahmathullah, Syed Nishath
Rahmathullah, Syed Nishath, Employee
  • 486 Points 250 badge 2x thumb
Hi Rafael,
Just to add by default 460 switch shipped along with "Advance Edge" license.
Reference link : http://documentation.extremenetworks.com/flr/downloads/ExtremeXOS_21.x_Feature_License_Requirements....
Thanks,Syed
