How to do PORT MIRRORING in Extreme x460-24t?
  • Question
  • Updated 3 years ago
Photo of Amit Jain
Amit Jain
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Jason Parker
Jason Parker, Employee
  • 3,038 Points 3k badge 2x thumb
i have a few notes and examples below
please note the warning
I also provide the limits at the bottom of the feedback
Extreme Mirror Mirroring
Slot-1 Stack.4 # enable mirror Jason to port 1:2
WARNING: This command will remove VLAN membership from the monitor port.
         Do you want to continue? (y/N) Yes
* Slot-1 Stack.6 # config mirror Jason add port 1:1
* Slot-1 Stack.7 # save configuration
The configuration file primary.cfg already exists.
Do you want to save configuration to primary.cfg and overwrite it? (y/N) Yes
Saving configuration on master .............. done!
Synchronizing configuration to backup .......... done!
Saving configuration on Standbys (Slots: 3).
Configuration saved on Standby (Slot 3): done!
 Slot-1 Stack.8 # show mirror
DefaultMirror   (Disabled)
    Description:    Default Mirror Instance, created automatically
    Mirror to port: -
Jason   (Enabled)
    Description:
    Mirror to port: 1:2
    Source filter instances used :  1
        Port 1:1, all vlans, ingress and egress
Mirrors defined:          2
Mirrors enabled:          1 (Maximum 4)
HW filter instances used: 1 (Maximum 128)
HW mirror instances used: 1 ingress, 1 egress (Maximum 4 total, 2 egress)
* Slot-1 Stack.15 # show mirror
    Mirror to port: -
Jason   (Enabled)
    Description:
    Mirror to port: 1:2
Mirrors defined:          2
* Slot-1 Stack.17 # config mirror Jason add port 1:1 vlan Jason ingress
* Slot-1 Stack.18 # show mirror
    Mirror to port: -
Jason   (Enabled)
    Description:
    Mirror to port: 1:2
    Source filter instances used :  2
        Port 1:1, vlan Jason, ingress only
Mirrors defined:          2
HW filter instances used: 2 (Maximum 128)
configure mirror DefaultMirror to port 1:3
enable mirror DefaultMirror
Extreme mirror
Configure mirror add port 18
To mirror to 19
Clear mirror    <--------------------------------------------------
Create- configure mirror DefaultMirror to port 19
-"Clears PM"
conf mirror "DefaultMirror" to port none  (removes dest port)
conf mirror "DefaultMirror" delete port 1:53 (removes mirror SP)
configure vlan Default add ports 25-26 untagged
configure mirror DefaultMirror add port 21 ingress-and-egress
notes:
conf mirror "DefaultMirror" to port 1:19
config mirror add port 1:53
* Slot-1 VC-P3-208.23 # enable mirror DefaultMirror
To view in config
show config | include Mirror
show conf vlan
Max #
16  ports
16 VLANs
128 traffic filters
Please Enjoy,
Jason Parker
