how to enable data collection for one port of my switch (series B5)
Visconti
New Contributor III
can anyone say me how to enable data collection for one port of my switch (series B5) ?
2 REPLIES 2
Zdeněk_Pala
I expect your question is about Extreme Management and B5, while the question is under EXOS. Tomasz did answer that
If your question is related to EXOS, please redefine your question.
Regards Zdeněk Pala
Tomasz
Valued Contributor II
Hello,
For statistics collection I recommend to do two things:
- with right-click on your B5 from devices list select 'Collect device statistics' and enable it;
- with right-click on your B5 from devices list go to View -> Interface summary, or Port tree, and over there you can right-click on the port and select 'Collect interface statistics' option.
Please remember to have correct SNMP credentials on both sides.
I recommend you to bookmark the XMC manual, which is also publicly available online: https://emc.extremenetworks.com/ - you will find a lot of other useful things inside. 🙂
Regards
Tomasz
