how to enable/disable trial license in extreme ware switches summit 400-24P ?
  • Question
  • Updated 3 years ago
  • Doesn't Need an Answer
Need to enable & disable trial License in Extreme Ware Summit 400-24P switch.
"show switch" output shows  : License:          *** ILLEGAL Advanced Edge ***.
Software Version: Primary EW Ver:   7.8e.4.1 [non-ssh]
Photo of Jitendra Patel
Jitendra Patel
  • 402 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Thomas, Ajo
Thomas, Ajo, Alum
  • 252 Points 250 badge 2x thumb
Hello Jitendra Patel,
You can clear the license information by execute the below command:
#clear license-info
If the switch you are using is on a trial license, you will need to use an alternate command to clear license information on the switch.
#debug epm clear trial-license
Hope this will help you!
Thomas, Ajo, Alum
Hello Jitendra,
I hope the below article may help you for the same:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-trial-license/
(Edited)
Jitendra Patel
Dear Ajo,
Thanks a lot. I will try above. I already tried #debug epm clear trial-license. but it did not worked. It works on XOS switches.
Jitendra Patel
Dear Ajo,
I tried #clear license-info  also but it is not working on Summit 400-24P.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,562 Points 10k badge 2x thumb
The command sent were for EXOS, not EW.
Need to dig in some old and deep archive to find a way
Jitendra Patel
Sure !!! Will wait for your reply.
Thanks in advance.
Regards,
Jitendra C Patel
