How to enable MPLS on ExOS VM ?
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
That ́s all...
MPLS is supported by ExOS VM ???
# sh verSwitch      : PN:1N2039    SN:123456   Rev 0.1 BootROM: 1.2        IMG: 15.3.2.11
PSUCTRL-1   : PN:MEAD      SN:MD1      Rev 0.1 BootROM: 2.1
PSUCTRL-2   : PN:MEAD      SN:MD2      Rev 1.1 BootROM: 2.3
mouse-usb   : PN:MOUSE     SN:4321     Rev 1.1 BootROM: 4.3
floppy-A    :
PSU-1       : Stack PS Slot # 2 PN:1N2039 SN:1234 Rev 0.1
PSU-2       : Stack PS Slot # 3 PN:1N2039 SN:1234 Rev 0.1
Image   : ExtremeXOS version 15.3.2.11 v1532b11 by release-manager
          on Tue Jun 18 15:25:24 EDT 2013
BootROM : 1.2
Photo of Oscar Belmar Madrid
Posted 4 years ago
Photo of adhe tri martika
adhe tri martika
  • 100 Points 100 badge 2x thumb
hi oscar, you need mpls feature pack like on real switch
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,676 Points 10k badge 2x thumb
Hi, this is just a license key, MPLS code is part of EXOS image. As such, for VM, I would recommend to enable trial license, unless you really want to purchase a license.
Thanks... I've already worked with every vendor's images that I found and configure mpls just for academic purpose. So, for Extreme OS  I've downloaded the VM version and integrated into a GNS3.
How can I get the license trial?
Can I extend or renew the trial period?
Regards,
OBM
Photo of Paul Thornton
Paul Thornton
  • 1,464 Points 1k badge 2x thumb
To turn on the 30 day trial, you use:
debug epm enable trial-license
You can re-enable after 30 days, but it needs a reboot.  Basically, the trial is fine for long term use in the lab as you can turn it on and off as you need.  In live network, the reboot requirement and lack of support makes it obviously a no-go.
Paul.
Photo of Darren Saliva
Darren Saliva
  • 662 Points 500 badge 2x thumb
Paul, I am using the EXOS VM with firmware version 15.3.2.11 and debug epm enable trial-license does not work. the enable command after epm does not exist. The only option after epm is "show". am i missing something?
just type it without trying auto-completion. I'd recommend you to upgrade the VM to a more recent release, btw.
Darren Saliva
Great thanks Stephane. The VM I'm using is the one I downloaded from the ekit site? where do i find a more up-to-date version of the VM?
Darren Saliva
Thanks Stephane. So I created the vm from the iso image and powered it on and it booted successfully. I then followed the install guide to add more nics, but now when I power on the vm it does not boot. I keep getting a watchdog warning message that has seconds that count up each time the error message appears.
Photo of Drew C.
Drew C., Community Manager
  • 40,586 Points 20k badge 2x thumb
Let's track this in a separate thread.
Please reference the new conversation here: EXOS-VM doesn't boot after adding more NICs
