how to enable openflow mode
  • Question
  • Updated 3 years ago
I have summit-X670-G2 switch, I had installed summitX-15.7.1.4-openflow.xmod and summitX-15.7.1.4.xos os on the switch, still I am able to use Open-Flow mode, Any problem with license ?
How can I enable Open-Flow mode on this switch ?
Photo of Prashant Chaugule
Prashant Chaugule
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
You need to add an OpenFlow license to enable it, the OpenFlow License part number for X670-G2 is 17134 ( ExtremeXOS SDN - OpenFlow Feature Pack for Summit X670 series switches ), after you add it, you will able to enjoy OF feature.
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
you should be able to enable it with trial license.
Prashant Chaugule
Where can I find this trial license ?
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Unfortunately, there isn't a trial license specific to OpenFlow.
Prashant Chaugule
Can you please tell then how can I use this switch with OF enable ?
