How to enable STP in Extreme Switches?
  • Question
  • Updated 3 years ago
  • Answered
is it possible configure STP for selected Ports alone? If possible please share the stps...
Photo of Thavamani Shanmugam
Thavamani Shanmugam
  • 710 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Dorian Perry
Dorian Perry, Employee
  • 2,302 Points 2k badge 2x thumb
Hi Thavamani,
Take a look the GTAC Knowledge article  How to configure RSTP in EXOS
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
Hi Thavamani,  By default, the Default VLAN is already a member of STP Domain s0.  If you created any additional VLANs, you could add those ports to the STP s0 domain using the following command:
configure stpd <domain> add vlan <vlan-name> ports <portlist>
The above command allows you to be specific about the ports you want to add.  If you do however wish to add all the ports, the auto-bind feature outlined in the article Dorian provided can be very handy.
Photo of Thiago da Silva
Thiago da Silva
  • 242 Points 100 badge 2x thumb
Hello Thavanami, I have the script of the configuration of the STPD. Do you question is about spanning-tree or STP ( Software of the inline-power - POE )?
Send my script of spanning-three.
create stpd <New ID STPD + ID of vlan> EX: VLan: 2000 --> STPD_2000config stpd <name stpd of vlan> add vlan <vlan name> ports <uplink ports> emistp
config stpd <name stpd of vlan> add vlan <vlan name> ports <acess ports> dot1d
or
config stpd <name stpd of vlan> ports link-type edge <access ports> edge-safeguard enable bpdu-restrict
config stpd <name stpd of vlan> tag <tag da vlan>
config stpd <name stpd of vlan> mode dot1w
enable stpd <name stpd of vlan>
enable stpd
Thiago da Silva
You can use the commands to see the stpd working.
show stpd
or
show stpd < name stpd >
(Edited)
