how to export report or view in extreme managment center
Visconti
New Contributor III
Can any one say me how export report, alarm list or view in extreme managment center ?
1 REPLY 1
StephanH
Valued Contributor III
Hello Visconti,
unfortunately, there is no general export function like in the java console (legacy tool).
You can export reports by sending via the scheduler (XMC->Tasks->Scheduled Tasks->Add).
In some views (not in the alarm panel) you see an Excel symbol in the corner. If you click there an export windows opens.
9466f977e0f140b2a3ec6d6ade3cc3ee_RackMultipart20180920-29757-1vk51rr-Export_inline.jpg
In my opinion here is a ToDo for the extreme people to create an export option on all table panels like in the legacy tool.
Best regards
Stephan
Regards Stephan
