How to get fan(s) status with SNMP of stack (x670v) ?
  • Question
  • Updated 2 years ago
  • Answered
We have a stack running with 3 x670v switches.
I want to make a SNMP get to get the fan status of the switches (slots) in the stack.
With a single switch I would use the following OID to get the status of the first fan.
OID for status of first fan -> 1.3.6.1.4.1.1916.1.1.1.9.1.4.101
for the second fan this would be 1.3.6.1.4.1.1916.1.1.1.9.1.4.102
as so on till 106.
In a stack configuration I always get (with the OIDs named above) the status of the fans of the master switch in the stack.
I searched the stacking branch of the extreme MIB but there is only stack related information available.
How do I get the status of the other switches in the stack ?
- fans/power/id/etc.
Kind regards,
Erwin
Photo of Erwin van Hoof
Erwin van Hoof
  • 366 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Balaji
Balaji, Employee
  • 776 Points 500 badge 2x thumb
Erwin,
If you do Get-next it would provide you the fan speed for the other slots.
So in the oid 1.3.6.1.4.1.1916.1.1.1.9.1.4.102 - 101 or 102 refers to the slot 1
If you would like to poll the slot 2 then it would 201 or 202 depending upon how many fans in that slot.
Erwin van Hoof
Thank you,
For the fans it is clear to me now.
But how does this work for the PSU (main and backup)?
And the temperature?
Photo of Balaji
Balaji, Employee
May i know what OIDs you are using to pull the PSU and temperature info?
