How to implement the third extreme switch on the stack?
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Hello to all,
This is my first post here at the community, and to be sincere, I am not very comfortable with extreme. However, here is my situation:
I've got 3 switch on stack, but 1 one them has just broken and I did the RMA and now I have a new one.
I already did the upgrade of firmware and applied the license. I want to know how can I ad this new one to the stack ?
Could you guys help me on it? if possible a step by step :)
Photo of ED CARLOS DEUS
ED CARLOS DEUS
  • 124 Points 100 badge 2x thumb
Posted 3 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
Hello Ed,
Welcome to the HUB!
If you are attempting to replace a node that was already present then you can simply use the directions below:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-replace-a-node-in-a-SummitStack
If you are attempting to add a node to an already existing stack where the slot hasnt been configured already then you can use the directions below:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-add-a-node-to-a-stack
It looks like you have done a lot of the grunt work on the new node. Just make sure the partition matches the stack (primary or secondary) and as long as the current master sees the new node all the commands can be placed into the master.
Please let us know if you have any questions. Stacking can get a bit tricky if you are not used to it.
Photo of David Coglianese
David Coglianese, Embassador
  • 6,594 Points 5k badge 2x thumb
What switches do you have?
When replaceing 460s and 440s we use the following procedure.
On the new switch:
Make sure you are running on the same partition of the stack
Make sure you are running the same code as the stack
<configure stacking protocol enhanced>
You can now connect the stack cables and while the new switch is rebooting.
Connect to the master and wait for the new switch to come online.
sh stacking
verify that the mac-address on the new switch matches what shows up next to disabled node on the current stack.
Copy the mac-address of the new switch.
Run these commands below from master switch:
sync stacking node-address "mac-address"
y
configure stacking node-address "mac-address" slot "x"
enable stacking node-address "mac-address"
reboot node-address "mac-address"
y
# Replacement switch will reboot and come online.
show slot
show stacking
You should be all set the new switch ports will be configured the way they were on the old slot
ED CARLOS DEUS
Hello,
and thank you to all for all the answers :)
I have the extreme switch  X460-48p
I will prepared myself to do the upgrade, thank you so much for all the answers.
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Ed, Welcome to The Hub.  We're here to help!
-Drew
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Good stuff Ed....great to have you join us.
Thanks for your trust in Extreme.
Photo of Pardeep Singh
Pardeep Singh
  • 90 Points 75 badge 2x thumb
(Edited)
