how to join NAC in a domain
  • Question
  • Updated 1 year ago
  • Answered
how can i join the NAC in a domain?
Thanks!
Photo of Marlon
Marlon
  • 1,570 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,442 Points 3k badge 2x thumb
Hi Marlon,
Please check this article.
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-do-I-know-if-the-NAC-has-joined-the-domai...
let us know if this answers your question.
Thanks,
Suresh.B
Photo of Marlon
Marlon
Hi Suresh,
thanks!
I can't find [NACInfoLogger] Joined Active Directory Domain logs in my NAC.
how can I join the NAC to active directory? is there any procedure?
thanks!
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 4,796 Points 4k badge 2x thumb
Hello,
The procedure to join to a NAC domain is done automatically with the onboard SAMBA package that is deployed. In order to trigger this join attempt you must have an Advanced AAA configuration with at least one line set to "LDAP Authentication" and pointed to an LDAP configuration that is set to "NTLM Authentication"
The NAC determines who the domain controller is to attempt to join by doing a DNS lookup of the domain configured.
The NAC uses the "user" and "Password" fields from the LDAP configuration to attempt to join the active directory.
The NAC will attempt to re-join the active directory if a nacctl restart is issued, or if a configuration change is made that removes, and then reapplies the LDAP authentication or NTLM authentication configuration pieces.
Thanks
-Ryan
Hi Marlon,
Please let us know if you have any further questions.
Thanks,
Suresh.B
Photo of Marlon
Marlon
Hi Ryan/Suresh,
thanks for the explanation.
unfortunately my NAC cannot joined the Domain.
i tried the kb below
https://gtacknowledge.extremenetworks.com/articles/Solution/802-1x-authentication-doesn-t-work-for-W...
result in our NAC
same result. do we need a certificate to join the NAC to domain?
thanks
Hello,
Please check out the following article. Typically these are permissions type issues that need to be looked at.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-Are-Reset-Password-Permissions-Needed-for...
Thanks
-Ryan
