How to login into extreme summit x440-24t switch?
  • Question
  • Updated 1 year ago
  • Answered
Hello Everyone.I have a summit exreme switch x440-24t i need to login the console,and i dont have serial cable with me can somebody give me the steps to login into it by providing default gateway and the connections.Thanks in advance.
Photo of venkatesh siddina
venkatesh siddina
  • 190 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Narayanan, Karthikeyan
Narayanan, Karthikeyan, Employee
  • 912 Points 500 badge 2x thumb
Hi Venkatesh,
Without consoling the switch I think we cant have a minimum configuration to access the switch.
This article will help you how to console the switch
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-console-into-Extreme-and-Enterasys-...
Regards,
Karthikeyan
(Edited)
venkatesh siddina
Hi Narayanan, Thankyou very much for swift response.
venkatesh siddina
Hi Narayanan,as above pics i got the same console cable but i have stack ports on back side of my switch which looks like chip,then how do i connect please help me regrading this.
(Edited)
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Venkat,
It is not possible to gain console access to the switch through an Ethernet connection.
For switches with an RJ-45 console connection (e.g. X440), it will be necessary to use an RJ-45 to DB-9 adapter or a rollover cable. If the PC does not have a serial port, a serial to USB adapter may also be necessary.
Also, have a look at this KB Article:-
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-connect-to-the-switch-console-via-R...
venkatesh siddina
Hi Vellachery, Thankyou very much for quick response.
venkatesh siddina
Hi Vellachery, Can i connect with  RJ45 cable switch to laptop by using third party software tool.Thanks in advance.
  • 2,172 Points 2k badge 2x thumb
Venkat,
One end of the RJ45 cable should be connected to your console port (usb port) of the X440 switch and the other end should be connected to the serial port of your laptop via using the DB9 connector as shown below:-
venkatesh siddina
Okay,Thankyou.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
I could see above some of very useful articles have been provided already by my colleagues. Adding to them please find below article says about:
  How to configure putty terminal-emulation software to access the local console of Extreme Switches?
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-putty-terminal-emulation-...
Hope all these will help you to crack your very concern.
(Edited)
venkatesh siddina
Hello Everyone,i wasn't able to login the console,what i did is i connected serial cable and installed putty and configured the ipaddress 192.168.10.x and the same ip given in putty and putty opened but it is not showing anything.can somebody help me please.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
please look at the following GTAC Knwoledge articles. The first describes how to use the serial console, the second how to use the Ethernet management port:
Erik
