How to MSS adjustment for TCP applications ?
  • Question
  • Updated 1 year ago
  • Answered
I want to adjust-mss of an interface to 1390. How can I do it in EXOS 16.2.1.6?
Photo of Weda
Weda
  • 994 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,034 Points 5k badge 2x thumb
You can change the MTU on our switches (default is 1500).  Which includes the MAC, IP, TCP, vlan headers.
The below wiki page has a example calculation from MSS to MTU.  Hope this helps
https://en.wikipedia.org/wiki/Maximum_segment_size
Photo of Weda
Weda
I want to adjust mss to 1390 in order to have a symmetry with 2 WAN connections.
but  I can set MTU as 1500. Below that, it is not allowed.
I would think the mss value would be set on the application.  Our switch doesn't look into the payload to check the MMS(maximum segment size).  We look at the MTU.
Photo of Bin
Bin, Employee
  • 5,370 Points 5k badge 2x thumb
Hello Weda,
Here is the reference about how EXOS MTU works.
Show size of MTU EXOS
https://community.extremenetworks.com/extreme/topics/show-size-of-mtu-exos
Hope it will help you.
Best regards,
Bin
