How to partition compact flash card
  • Problem
  • Updated 1 year ago
  • Solved
I have a Summit X350-48t which has XOS booting issue. Nothing comes up in serial console and Mgmt LED blinks a little faster than usual. I already have the fresh copy of XOS image for this switch but having a little problem with flash partitioning. I opened up the switch, accessed it with a compact Flash card reader. it is 256MB capacity of card. It was showing only 19 MB of valid partition. I partitioned it with diskpart and copied XOS image to single partitioned CF card but problem still exists. is there any special method to partition flash card or am I missing any other file other than XOS file?
Photo of Aneeq Zia
Aneeq Zia
  • 240 Points 100 badge 2x thumb
  • sad
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
Hello Aneeq,
Did you reach out to GTAC before proceeding with this method? There are ways to reload an image without opening the box. This can be done through the Bootrom:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Use-the-Boot-Rom-Menu-to-Download-a...
Photo of Aneeq Zia
Aneeq Zia
I read this before opening up the switch, and there was nothing coming up on the console, so no benefit of pressing space bar. since its an old switch, warranty expired and no service contract in place, therefore decided to do some engineering on my own.....
Patrick Voss, Alum
How do the capacitors look on the switch? Are any of them bulging?
Photo of Aneeq Zia
Aneeq Zia
capacitors look fine, not even a sign of burning like smell.
(Edited)
Patrick Voss, Alum
I apologize, I believe this issue is due to something hardware related. We have seen this issue before and the lack of console output is more evidence that the switch is defective. The partitioning of the memory chip itself is not something we typically work on. I will allow someone else to provide more information if there is any.
Photo of Aneeq Zia
Aneeq Zia
Thanks Patric, Looking forward to anything helpful....
Photo of Aneeq Zia
Aneeq Zia
Can someone tell, what other files do we need to have in flash other than .xos file?
Photo of Drew C.
Drew C., Community Manager
  • 38,610 Points 20k badge 2x thumb
The .xos file does not go on the CF card directly. It's an installer for the full filesystem. Since the partitions have been destroyed, the only way forward would be to use the BootROM method that Patrick mentioned earlier. Have you tested that your console/serial connection works on another device?
Photo of Aneeq Zia
Aneeq Zia
Yes, it does work on one of the PoE Switch
