How to reduce/load balance Bandwidth utilization on a Single Link between two Core Switch.
  • Problem
  • Updated 4 years ago
Hi, Please advice on How to reduce/load balance Bandwidth utilization on a Single Link  between two Core Switch?
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Posted 4 years ago
Photo of Ravisekar, Rajamanickam
Ravisekar, Rajamanickam, Alum
  • 232 Points 100 badge 2x thumb
Hello Yan Linn Aung,
1   If you are running VRRP, you can load share the master and backup between the cores.
For example
For odd vlan tag you can have core1 as master and for even vlan tag you can have core2 as master
2 You can group the ports between the core
Photo of Paul
Paul
Hi Ravisekar,
Please kindly provide the sample configuration commands. Thanks!
Hello Yan Linn,
  Sample config for vrrp. In the configuration  I am creating two vlans , vlan9 and vlan10 and then going to run VRRP between them
Core1
create vlan vlan9 tag 9
conf vlan vlan9 ipaddress 192.168.9.11/24
conf vlan vlan9 add ports XXX
create vlan vlan10 tag 10
conf vlan vlan10 ipaddress 192.168.10.11/24
conf vlan vlan10 add ports XXX
create vrrp vlan vlan10 vrid 1
create vrrp vlan vlan9 vrid 1
configure vrrp vlan vlan10 vrid 1 add 192.168.10.10
configure vrrp vlan vlan9 vrid 1 add 192.168.9.10
enable vrrp vlan vlan10 vrid 1
enable vrrp vlan vlan9 vrid 1
Core 2
conf vlan vlan9 ipaddress 192.168.9.10/24
conf vlan vlan10 ipaddress 192.168.10.10/24
configure vrrp vlan vlan10 vrid 1 priority 255
configure vrrp vlan vlan9 vrid 1 priority 255
From this configuration core 2 act as default gateway for both vlans since priority in core 2 is set higher than core 1. If you want to load balance for vlan 9 you can configure higher priority in core1 and leave the priority to the default value(100). Below is the output from show commands
core1
 sh vrrp
                      Virtual                 Master
   VLAN Name VRID Pri IP Address        State MAC Address       TP/TR/TV/P/T
  vlan10(En) 0001 100 192.168.10.10       BKUP 00:00:5e:00:01:01  0  0  0 Y 1
   vlan9(En) 0001 100 192.168.9.10        BKUP 00:00:5e:00:01:01  0  0  0 Y 1
  En-Enabled, Ds-Disabled, Pri-Priority, T-Advert Timer, P-Preempt
  TP-Tracked Pings, TR-Tracked Routes, TV-Tracked VLANs
Core2
 sh vrrp
                      Virtual                 Master
  vlan10(En) 0001 255 192.168.10.10       MSTR 00:00:5e:00:01:01  0  0  0 Y 1
   vlan9(En) 0001 255 192.168.9.10        MSTR 00:00:5e:00:01:01  0  0  0 Y 1
Static grouping configuration is simple.. If you have 4 ports from core1 are connected to core2. Lets take example as ports 40 to 44. (40 is the master port of the group that means after enabling sharing , any changes on port 40 will change the config on that group ports41-44)
enable sharing 40 grouping 40-44
Additionally if you want to set algorithm for loadsharing you can add few more in the above command
enable sharing 40 grouping 40-44 algorithm address-based/port based
These all for static sharing , if you want to enable LACP mode you can do as below
enable sharing 40 grouping 40-44 LACP
Photo of Paul
Paul
Thanks  Ravisekar,
Even after i enable Lacp .. port is not sharing. Utilization is high on Link 1 only. I want to use load balance on both links. Please kindly see the below output and advice thanks.
* I try L2 static, L3_L4 and LACP. all the same ports are not load balance. *
enable sharing 1 grouping 1,4
enable sharing 1 grouping 1,4 L3_L4
enable sharing 1 grouping 1,4 algorithm address-based L3_L4 lacp
CoreSW # sh port 1,4  utilization bandwithPort     Link    Link   Rx             Peak Rx       Tx            Peak Tx
         State   Speed  % bandwidth    % bandwidth   % bandwidth   % bandwidth
Link_1> A       1000     82.06         94.94         48.23           55.72
Link_2> A       1000      0.25          0.30          1.34            1.57
          > indicates Port Display Name truncated past 8 characters
          Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
CoreSW #sh sharing
Load Sharing Monitor
Config    Current    Agg       Ld Share    Ld Share  Agg   Link    Link Up
Master    Master     Control   Algorithm   Group     Mbr   State   Transitions
     1      1        LACP      L3_L4       1          Y      A        0
                                        L3_L4       4          Y      A        0
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Load Sharing Algorithm: (L2) Layer 2 address based
                        (L3_L4) Layer 3 address and Layer 4 port based
Number of load sharing trunks: 1
Please kindly advice. Thanks.
(Edited)
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
write an acl to drop unnecessary multicast trafic sent from host.
Are you using Mlag,STP ,RSTP,ESRP?
Any of the above protocols there are better options.
is this a triangular toplogy.
In show sharing you must see all the ports in lag.
could you check the configuration.
on both the switches.
enable sharing 1 grouping 1,2 algorithm address-based l2
Photo of Paul
Paul
CoreSW #sh sharing
                                        L3_L4       4          Y      A        0
