How to remove a netflow collector ip from a switch.
Thomas_Maddox
I am new to the Extreme side of things. I was tinkering with Purview this morning. I added the export destination to my Peview server and quickly found that I was over the licensing limit. I want to turn it off temporarily until we get our licensing figured out. I cannot seem to find reference on how to remove a destination IP from the list of Netflow servers in the CLI of my SSA. Please help.
3 REPLIES 3
Thomas_Maddox
Thanks Frank. I actually found the command by doing some deep digging about the time your reply popped up.. Why is it that the command reference for EOS seems hard to find?
I take it you found them Thomas, which is good. Sorry it was difficult.
http://www.extremenetworks.com/support/documentation
We're working very hard to bring Unified Search to the Extreme web properties. Hope to have an announcement in early 2016.
In the interim, GTAC Knowledge is usually pretty good at directing traffic, as well as the Hub: https://gtacknowledge.extremenetworks.com. We also try to be as friendly to Google as we can.
We're going to make it much easier to find stuff very soon. Thanks for joining the Hub and your trust in Extreme.
Frank_Thomas
clear netflow export-destination X.X.X.X
