How to replace Stacking Switch with different model.
  • Question
  • Updated 3 years ago
  • Answered
Hi all,
My question is How Can I Add Different Module/model to the current configured Module/model. Please see below for more detail.
I have uploaded the configuration to the Stack.
Current Configuration for Slot 1 is  X250e-48t
and Now Replacement unit module is X250e-48p
if i use unconfigure slot 1.
Configuration will wipe out slot 1 config. I have to reconfigure the configuration it will not easy for the operation and during hardware replacement.
Please advice. How can i achieve without effecting the current config for port and vlan for slot 1 except changing from X250e-48t to X250e-48p. Thanks.
Slot-2 SW # unconfigure slot 1
 This slot will be rebooted as part of this operation.
 This will remove all port and vlan information for ports in this slot(1).
 Any ports on this slot that are members of load share groups will be removed
 from the load share group.
 Continue ? (y/N)
configure slot 1 module X250e-48t
configure sys-recovery-level slot 1 reset
configure slot 2 module X250e-48t
configure sys-recovery-level slot 2 reset
Slot-2 SW # sh slotSlots    Type                 Configured           State          Ports
Slot-1   X250e-48p            X250e-48t                                   Mismatch      50
Slot-2   X250e-48t             X250e-48t                                 Operational       50
Slot-2 SW # sh slot 1
Slot-1 information:
     State:               Mismatch
     Download %:          0
     Last Error:          Card Mismatch
     Restart count:       0 (limit 5)
     Serial number:       N/A(0) N/A(0)
     Hw Module Type:      X250e-48p
     Configured Type:     X250e-48t
     Ports available:     50
     Recovery Mode:       Reset
     Node MAC:            02:04:96:28:22:1B
     Current State:       FAIL (Card Mismatch)
     Image Selected:      secondary
     Image Booted:        secondary
     Primary ver:         15.3.3.5
     Secondary ver:       15.3.3.5
     Config Selected:     primary.cfg
Slot-2 SW #
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,442 Points 3k badge 2x thumb
Hi Paul,
Please follow below article to add a new node to exiting stack.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-add-a-node-to-a-stack/
Thanks,
Suresh.B
(Edited)
Photo of Paul
Paul
Hi Suresh,
Thanks. My problem right now is Replacing the Stack Switch with different model. Please assist.
Hi Paul,
I would suggest to you do this activity under maintenance window.
 We have to unconfigure slot 1 and this will remove the configuration from the node that to be
replaced from stack.
 All configuration parameters (except for the related node's NVRAM-based configurations such as
stacking parameters, image to be used, and failsafe account) for the slot will be erased.
 Follow the steps to add a new node which I have shared on the article and load the modified configuration to the replacement switch.
Thanks,
Suresh.B
Photo of Paul
Paul
Hi Suresh,
Noted. Thank you for your attention to this matter.
- Paul
